Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 11-21-2007, 09:31 PM   #1
air66stream
Profile:  1966 26' Overlander
Conover , Ohio
no back up lights
While I have my 66 Overlander torn apart, I noticed that I have a black wire at the rear of the trailer that is for back-up lamps. The wire is just taped off with nowhere to go. Was this an option, or just not common in 66? The outer tail lamp/brake/signal is the only one that is functional. The inner is either a fake, or simply a reflector. Is this where the backup lamp should go if I make the upgrade, or does it go somewhere else on the body? Does anyone have a pic of a back-up lamp on an older Overlander?
Thanks for all the help. This project wouldn't have got off the ground without all the help this forum has given me. Tom
air66stream is offline   Reply With Quote
Old 11-21-2007, 09:46 PM   #2
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
If you look at various photos on the Vintage Airstream site it looks like 1967 was the first year for backup lights. Here's the rear of a 67 Overlander with the backups mounted above the bumper.
Vintage Airstream Home
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 11-21-2007, 10:57 PM   #3
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
The back up lights were an option.
A couple of dealers have the original back up light assemblies.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 11-22-2007, 09:43 AM   #4
centennialman
centennialman's Avatar
Profile:  1966 22' Safari
Centennial , Colorado
I have the back up lights on my 66 Safari and they are just above the bumper, like the photo above. I didn't realize they were an option.
When I first purchased my Airstream, one of them didn't work. I was able to get the local service department at my Airstream dealer to install a new one. Works fine now.
The "light" to the inside of the brake lights is a reflector on mine.
Steve
centennialman is offline   Reply With Quote
Old 11-22-2007, 10:52 AM   #5
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
If you are considering putting back up lights on your trailer and don't want to distroy to original look of the rear and have a brighter light consider putting lights in the fender well. There they are much more effective because you can install a very bright light and they are located where you need to light, At the Axles.
See the picture below.
http://www.airforums.com/photos/show...?i=17603&c=507
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
back up lights dhunt28 Lights - Interior & Exterior 3 03-25-2006 06:48 AM
Back Up Lights Staying On GT1963 Towing, Tow Vehicles & Hitches 9 11-28-2004 02:08 PM
Back-up lights femuse Electrical - Systems, Generators, Batteries & Solar 8 08-19-2004 08:02 AM
back up lights john hd Lights - Interior & Exterior 0 12-27-2002 07:54 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 07:43 PM
