Old 07-21-2010, 07:32 AM   #1
1985 34' Limited
Morven , Georgia
newbie with electrical problems
Hi everyone! We have a 1985. It was all good and we set up and put in a pole on property to keep frig etc. on while not in use. After a while something happened. Now frig. Microwave and lights don"t work. Air works and all plugins work. All fuses and breakers have been checked. Any suggestions would be very much appreciated.
busymom40 is offline   Reply With Quote
Old 07-21-2010, 09:21 AM   #2
nick6930's Avatar
1979 Argosy 27
1969 21' Globetrotter
1953 25' Cruiser
Front Royal , Virginia
Check your converter. The lights should be 12v from the battery but most converters have fuses as well. Do you have the battery hooked up and is it charging working? Do you have more than one fuse box?
Good luck
nick6930 is offline   Reply With Quote
Old 07-21-2010, 11:35 AM   #3
Mexray's Avatar
1978 28' Ambassador
Morada , California
Lights are 12 volts, and are powered by the converter/charger if you don't have any battery installed, like Nick mentioned above...
If the microwave isn't working, you'll have to check the voltage where it's plugged in - get a multi-meter and check the AC voltage (115 volts AC)...if there's no voltage at that receptacle, then it's probably a circuit breaker that powers that receptacle...
It's possible that both receptacles (converter & microwave) are on the same AC circuit, and that the refer's AC power is on that circuit as well...
You mentioned you 'checked' the circuit breakers - in an older RV, it's entirely possible the circuit breaker itself is faulty - switch the breakers on and off several times to see if there is any 'difference' in the way they 'feel' when tripped to see if one is loose inside - if that fails, you'll have to remove the panel cover (with the AC power OFF, or unplugged from your pole) and check breaker with a multi-meter...
Breakers are not very expensive, and you can find a replacement at a hardware store - take in the old breaker to get the proper type...
Good luck...
Ray
Ray & Pat; Morada, CA
Old 07-21-2010, 11:42 AM   #4
richinny's Avatar
2011 34' Classic
in my 94 34', there is a switch above the galley sink, in an overhead cabinet, that lets you use the ac OR microwave. you trailer may be different.
Ricky
Old 07-21-2010, 01:20 PM   #5
1972 31' Sovereign
1985 31' Excella
2010 31' Classic
Hendersonville , Tennessee
Our 85 Excella has the switch above the sink as well, you can have power to the microwave or the air not both.
NashBuff is offline   Reply With Quote
Do you have problems getting WiFi in your Airstream? WiFiRanger Electronics & Connectivity 27 02-08-2012 01:01 AM
Newbie... Please help or offer your .02 worth breckfarm 1998 Excella 1000 15 09-14-2011 09:36 PM
Remote Electrical Troubleshooting - Prep TxToaster Electrical - Systems, Generators, Batteries & Solar 2 08-21-2011 05:08 PM
Electrical? Water heater? Water pump? robwok 1960 - 1964 Overlander 6 02-09-2011 11:53 AM
'67 Caravel Restoration Electrical question vonzellen 1966-68 Caravel 1 01-15-2011 07:25 AM
