Old 08-16-2009, 07:17 PM   #1
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
new tailight covers - mis-matched screw holes
friends,
as a week-end project i decided to replace the "old" [a 2005 22'] "corroded" exterior rear plastic light covers.
imagine my surprise when i found out that the left cover was held on by 3 screws and the right one by 4 screws.
apparently the 4-hole set-up is correct since the replacment covers each had 4 holes.
out came the drill and using the old pieces as template i had to drill a new set of holes for each of the left side covers.
so - my 15 minute project took almost 2 hours as i sweated the details and made sure not to make any mistakes.
is it only me or are things very strange in the mfg department?
let that be a lesson to all of us - look before you renovate
az-streamer
ps.
ID:	85491   Click image for larger version
ID:	85493   Click image for larger version
Name:	Copy of Copy of page 1 005.jpg
Name:	Copy of 101_6698.jpg
az-streamer
Jon & Deb
Phoebe & Ellis - Airstreaming Mini-Schauzers
FCU WBCCI #1601
I Donít Always Pull A Trailer
But When I Do - I Pull An Airstream
Keep Moving My Friends
az-streamer is offline   Reply With Quote
Old 08-16-2009, 08:38 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Must have been putting that 3 screwed one in just prior to break or the end of the day. When the quitting whistle sounds it ARE TIME TO GO! Or they changed suppliers mid stream. IMHO Airstream QC is an oxymoron, they used decent materials but still fall prey to the human error factor.
Aaron
WBCCI #XXXX AIR #2495
Old 08-16-2009, 08:39 PM   #3
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Great work. The license plate light looks terrific. What did you use to shine it?
BTW, I'm just a few miles west of you, down the Carefree Hwy in Desert Hills.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 08-17-2009, 03:02 PM   #4
Images: 20
mello mike,
thanks. didn't shine it at all. this is how the new one looks right out of the box.
altho i guess i will have to make sure it looks nice now that i'm doing some projects.
az-streamer
az-streamer
Jon & Deb
FCU WBCCI #1601
Old 08-17-2009, 03:08 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Are you saying that license plate light was on a 2005 or a 1965 trailer? parked under salt water should not do that in 4 years.
2004 Excursion 4x4
Old 08-17-2009, 03:10 PM   #6
Images: 20
Aaron
yeah, i'm still really puzzled. 3 on one side, 4 on the other. and these were factory drilled and installed.
made me run outside to take another look at my wheels . okay - 2 on each side - whew.
you might be right about QC. glad i bought used instead of paying top dollar for new.
az-streamer
az-streamer
Jon & Deb
FCU WBCCI #1601
Old 08-17-2009, 03:48 PM   #7
CanoeStream's Avatar
St. Cloud , Minnesota
Originally Posted by az-streamer View Post
mello mike,
az-streamer
Does a magnet attract to it? Then it's only nickeled steel -- very rust prone. That sez it all as far as my experience with this part. With or without seashore exposure -- although worse-for-wear if it has spent any moment seaside or being transported on salted northern roads in the winter.
az-streamer, you have me wondering if there's a different guy on the right & left sides of the line as the unit is being pulled together just before rollout. The rough openings were exactly the same?
5 meter Langford Nahanni
Old 08-17-2009, 07:56 PM   #8
Images: 20
howieE,
yep, its a 2005 but it spent 05 to present in the Cape Cod area so there was plently of heat, salt and humidity.
now that its here in AZ i've taken 2 of 3 out of the equation. all that remains is the extreme heat. hope the piece lasts longer.
az-streamer
az-streamer
Jon & Deb
FCU WBCCI #1601
Old 08-17-2009, 08:07 PM   #9
Images: 20
the rough openings in the shell were rough and i could not tell if they were similar. i did not change out the large metal housings, only the chromed plastic covers.
the 3 holes in the metal housing on the left looked as "official" as the 4 on the right. as did the holes in the original plastic light housings.
then, the replacement parts - which came from the factory - only had the 4 holes. go figure.
az -streamer
az-streamer
Jon & Deb
FCU WBCCI #1601
Old 08-18-2009, 01:21 AM   #10
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, my 2005 Safari has the rust prone license light too. I replaced it once, but I'm sure it will be a, every few years, maintainence item. As for the three screws in the cheap plastic tail-light bezel, that is what came on my trailer, but later Airstream changed to the four screw bezel. I'm trying to find something in stainless steel. The only one I found so far is ugly.
Name:	My Picture CD 448 (Large).jpg
ID:	85604   Click image for larger version
Name:	tail lights.jpg
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-18-2009, 06:51 AM   #11
hookedonclassic's Avatar
Fond du Lac , Wisconsin
Not trying to mis-direct this thread but I noticed the screws to the light lenses on my AS looked rusted. I'm replacing screws today with stainless steel screws. Metric thread - M5.
Rich
2010 43' Newmar Dutch Aire
formerly 2006 34' Classic
Changing the World One Child at a Time
www.compassion.com
hookedonclassic is offline   Reply With Quote
Old 08-18-2009, 10:01 AM   #12
Images: 20
Originally Posted by ROBERTSUNRUS View Post
As for the three screws in the cheap plastic tail-light bezel, that is what came on my trailer, but later Airstream changed to the four screw bezel....
robertsun,
thanks for the info. but why did they decide to do the change-over in the middle of working on MY AS .
oh well, it could have been worse. i could have had the 3 screwhole setup on all 4 of the mounts. then i would have had to re-drill 4 sets of holes.
az-streamer
az-streamer
Jon & Deb
FCU WBCCI #1601
Old 08-18-2009, 12:46 PM   #13
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
az-streamer, where did you buy your license plate light assembly and how much was it?
1958 Overlander
4CU 1st VP
Old 08-19-2009, 10:41 AM   #14
Images: 20
license plat ass'y
mello mike,
i bought the pcs from orangewood rv on bell rd in surprise az.
the license plate assy included the metal housing, white license plate holder, bulb socket with wires and foam spacer was $65.
i only changed out the metal cover since the other pcs were okay. figured i'd save the other items until i really needed them. no sense doing unnecessary electrical work.
az-streamer
az-streamer
Jon & Deb
FCU WBCCI #1601
Has anyone matched factory flooring in 1998? redstart Floor Finishes 10 02-13-2009 06:50 PM
Caulk the old screw holes?? Tidal Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-30-2007 03:46 PM
Patching Old Screw Holes on Zolatone? cloud55 General Interior Topics 6 01-25-2006 06:42 PM
Screw holes in Tradewind floor yochanan Repairing/Replacing Floor &/or Frame 1 01-21-2006 11:50 PM
Screw holes in my skin 58BUBBLE Ribs, Skins & Rivets 11 09-12-2004 09:53 PM
