08-16-2009, 07:17 PM
Wheels Itch)(Must Travel
2014 25' FB Flying Cloud
- east coastal area -
new tailight covers - mis-matched screw holes
friends,
as a week-end project i decided to replace the "old" [a 2005 22'] "corroded" exterior rear plastic light covers.
imagine my surprise when i found out that the left cover was held on by 3 screws and the right one by 4 screws.
apparently the 4-hole set-up is correct since the replacment covers each had 4 holes.
out came the drill and using the old pieces as template i had to drill a new set of holes for each of the left side covers.
so - my 15 minute project took almost 2 hours as i sweated the details and made sure not to make any mistakes.
is it only me or are things very strange in the mfg department?
let that be a lesson to all of us - look before you renovate
az-streamer
ps.
az-streamer
Jon & Deb
Phoebe & Ellis - The Airstreaming Mini-Schauzers
[CENTER][I]
08-16-2009, 08:38 PM
Rivet Monster
1975 31' Sovereign
1980 31' Excella II
Sprung Leak
, North Carolina
Must have been putting that 3 screwed one in just prior to break or the end of the day. When the quitting whistle sounds it ARE TIME TO GO! Or they changed suppliers mid stream. IMHO Airstream QC is an oxymoron, they used decent materials but still fall prey to the human error factor.
Aaron
WBCCI #XXXX AIR #2495
08-16-2009, 08:39 PM
1958 26' Overlander
Mesa
Great work. The license plate light looks terrific. What did you use to shine it?
BTW, I'm just a few miles west of you, down the Carefree Hwy in Desert Hills.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
08-17-2009, 03:02 PM
mello mike,
thanks. didn't shine it at all. this is how the new one looks right out of the box.
altho i guess i will have to make sure it looks nice now that i'm doing some projects.
az-streamer
az-streamer
Jon & Deb
[CENTER][I]
08-17-2009, 03:08 PM
Princeton
, New Jersey
Are you saying that license plate light was on a 2005 or a 1965 trailer? parked under salt water should not do that in 4 years.
2004 Excursion 4x4
08-17-2009, 03:10 PM
Aaron
yeah, i'm still really puzzled. 3 on one side, 4 on the other. and these were factory drilled and installed.
made me run outside to take another look at my wheels . okay - 2 on each side - whew.
you might be right about QC. glad i bought used instead of paying top dollar for new.
az-streamer
az-streamer
Jon & Deb
[CENTER][I]
08-17-2009, 03:48 PM
St. Cloud
Originally Posted by az-streamer
mello mike,
az-streamer
Does a magnet attract to it? Then it's only nickeled steel -- very rust prone. That sez it all as far as my experience with this part. With or without seashore exposure -- although worse-for-wear if it has spent any moment seaside or being transported on salted northern roads in the winter.
az-streamer, you have me wondering if there's a different guy on the right & left sides of the line as the unit is being pulled together just before rollout. The rough openings were exactly the same?
08-17-2009, 07:56 PM
howieE,
yep, its a 2005 but it spent 05 to present in the Cape Cod area so there was plently of heat, salt and humidity.
now that its here in AZ i've taken 2 of 3 out of the equation. all that remains is the extreme heat. hope the piece lasts longer.
az-streamer
az-streamer
Jon & Deb
[CENTER][I]
08-17-2009, 08:07 PM
the rough openings in the shell were rough and i could not tell if they were similar. i did not change out the large metal housings, only the chromed plastic covers.
the 3 holes in the metal housing on the left looked as "official" as the 4 on the right. as did the holes in the original plastic light housings.
then, the replacement parts - which came from the factory - only had the 4 holes. go figure .
az -streamer
az-streamer
Jon & Deb
[CENTER][I]
08-18-2009, 01:21 AM
Salem
, Oregon
Hi, my 2005 Safari has the rust prone license light too. I replaced it once, but I'm sure it will be a, every few years, maintainence item. As for the three screws in the cheap plastic tail-light bezel, that is what came on my trailer, but later Airstream changed to the four screw bezel. I'm trying to find something in stainless steel. The only one I found so far is ugly.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
08-18-2009, 06:51 AM
Fond du Lac
, Wisconsin
Not trying to mis-direct this thread but I noticed the screws to the light lenses on my AS looked rusted. I'm replacing screws today with stainless steel screws. Metric thread - M5.
Rich
2010 43' Newmar Dutch Aire
formerly 2006 34' Classic
Changing the World One Child at a Time
www.compassion.com
08-18-2009, 10:01 AM
Originally Posted by ROBERTSUNRUS
As for the three screws in the cheap plastic tail-light bezel, that is what came on my trailer, but later Airstream changed to the four screw bezel....
robertsun,
thanks for the info. but why did they decide to do the change-over in the middle of working on MY AS .
oh well, it could have been worse. i could have had the 3 screwhole setup on all 4 of the mounts. then i would have had to re-drill 4 sets of holes.
az-streamer
az-streamer
Jon & Deb
[CENTER][I]
08-18-2009, 12:46 PM
1958 26' Overlander
Mesa
az-streamer, where did you buy your license plate light assembly and how much was it?
1958 Overlander
4CU 1st VP
08-19-2009, 10:41 AM
license plat ass'y
mello mike,
i bought the pcs from orangewood rv on bell rd in surprise az.
the license plate assy included the metal housing, white license plate holder, bulb socket with wires and foam spacer was $65.
i only changed out the metal cover since the other pcs were okay. figured i'd save the other items until i really needed them. no sense doing unnecessary electrical work.
az-streamer
az-streamer
Jon & Deb
[CENTER][I]
08-19-2009, 11:05 AM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Check these out too:
Exterior Lights... this one looks the same and only $32.99.
Sorry az-streamer, but gotta save a fellow forum member $$ whenever possible~
Shari
08-19-2009, 11:07 AM
St. Cloud
Rich, this is a well documented issue and many have done the stainless (metric) changeover. I couldn't find the same length when I did mine but there was plenty of depth inside the light assembly to take a screw 0.5cm longer.
A buddy with a 2008 had those screws bedded in a bit of caulk where the head meets the lens. Earlier units saw a lot of condensation inside the teardrop shaped lens. Lewster & silvertwinkie have posted how-to's involving using O-rings instead of caulk. So I used O-rings when I did the screw replacement with mine.
08-19-2009, 02:00 PM
Shari
shari,
thanks for the info. you're right about saving $$$$. my wife and i forsee plenty of projects ahead.
i'll keep this source on file.
do you know if these parts are from AS or are they from an aftermarket supplier? I'm trying to keep my AS as "original" as possible.
az-streamer
az-streamer
Jon & Deb
[CENTER][I]
08-22-2009, 11:37 PM
Salem
, Oregon
Found them.
Hi, after more searching, I found some stainless steel bezels that look pretty good. [in the picture anyhow] After I get them and install them, if they work out as planned, I will post of pictures of the finished product.
09-10-2009, 10:59 PM
Salem
, Oregon
Hi, today I received my new stainless steel tail light bezels. They are not as fancy as the hooded plastic bezels that came from the factory, but they won't rust or corrode. I determined that the grade of stainless steel is good because my magnet won't stick to them. Because they came with tiny stainless steel screws that screw into the rubber grommets, I had to buy new grommets. With the exception of the corrosion spots on the cast aluminum housings, that won't easily clean up, I think it still looks good.
