Old 08-15-2013, 08:35 PM   #1
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
New clearance lights ( wiring)
I'm putting my trailer back together and will likely replace all of the original wiring. The old clearance lights ran off of a positive wire, the negative was grounded to the shell. The replacement lights I bought are set up with positive and negative wiring. So, for the eventual total rewire, should I use the ground-to-shell strategy, or run a negative wire ?
Old 08-15-2013, 10:19 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
Either will work. Electrical connections to the shell are a possible source of trouble. By wiring the negative connections together and attaching them to a common ground, you can end up with more reliable lighting over a period of many years.
That said, I grounded mine to the shell at each light, because I did not remove the interior panels necessary to get access to the wires.
Old 08-15-2013, 10:23 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, run new ground wires, it will be so much better. I've worked on campers with no ground wires and stripped mounting screws; No fun trying to get them all working.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-20-2013, 05:26 AM   #4
rayandre's Avatar
1970 27' Overlander
Shaker Heights , Ohio
Depends if your interior shell is removed currently. I was not doing a full shell off resto so I ditto Jammers method on our replacements and ground each light to the shell. I did this after polishing the exterior and getting ready for a road trip out West. We recently came back from the trip and we did 6300 miles through 9 states with no problems to the running lights-worked great and were brighter than ever!
Ray Juaire
WBCCI-6849 . TAC OH-22
It is impossible to achieve the aim without suffering-unknown source from a Robert Fripp album-
rayandre is offline   Reply With Quote
Old 08-20-2013, 07:30 AM   #5
Belegedhel's Avatar
Houston , Texas
Well, it turned out that I must have been seeing double when I reported that the new lights had a positive and negative wire, because when I went to install them, the negative was set up to ground to a fastener through the shell, and there was only a positive wire. Anyway, all new lights are in place, just need to run the new wiring and test.
