Old 11-27-2013, 01:12 AM   #15
okotoks , Alberta
I have water in two of my rear red led lights on the top , more like drops , if it's inside the lights , does it mean they have to be replaced or can they be dried out ,
dutchie is offline   Reply With Quote
Old 11-27-2013, 03:20 AM   #16
Andrew T's Avatar
2008 34' Classic
1960 17' Pacer
London , Ontario
I have another thought for you.
Make a list of these sorts of items and sometime before you are out of warranty take a trip back to your dealer to have them all looked after. If you have a more serious problem pop up in the mean time you can have it all done at once but in the mean time just use it and enjoy it.
Andrew T
Andrew Thomson
London, Ontario
"One test is worth a thousand expert opinions."
Tex Johnston, Boeing 707 test pilot
Andrew T is offline   Reply With Quote
Old 11-27-2013, 03:57 AM   #17
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Dutchie, if I remember correctly, you have a new 2013 Int. That means you have the new LED lights and the newer, larger black gaskets under the chrome bases. According to AS and most dealers, those gaskets were supposed to stop the lights picking up condensation. So much for that fix.. The way water gets into the lights 90% of the time is through the area where the wires enter in the back. If the wires are sealed right, they won't leak, if not, water shows up sooner or later. The fix of putting the Classic trailer cast bases under the lights and then sealing all parts with Acryl R or ParBond stops all leaks. The rubber gaskets you have, stops the Filiform from starting at the front and rear edges of the base, but does nothing to give additional waterproofing of the light. My opinion, and if I had the lights with new gaskets, I would at least still seal, with Acryl R, the plastic led light to its chrome base. (Stop water from getting in between those two parts and thus keeping it away from the wires in back.)
Dry out water already inside? 1, Time and heat. 2, Drill small hole to dry out, then re-seal. 3, warrantee--get new lights installed.
Howard L. is offline   Reply With Quote
Old 11-27-2013, 05:06 AM   #18
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
X2
Droplets on the inside of the lens=condensation.
When repairing the base gaskets on our older Classic I noticed the lens' with little condensation had a small v in base edge pointy end. I enlarged the existing ones slightly and duplicated on the rest. I still get some drops but they do dry out in the sun....mostly.
Standing water...re-seal.
POI I use dielectric grease on the lens edge and acryl-r on the curb.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 11-27-2013, 06:07 AM   #19
acstokes's Avatar
2009 30' Classic
Melbourne, FL , Searsport, ME
X3
All 4 of my LED tail lights burned out because moisture got inside the lenses. This was pre-rubber gasket days, but apparently the gasket alone does not cure the problem. Moisture is more detrimental to LEDs than incandescent fixtures because LEDs don't generate enough heat to evaporate the moisture out. Seal those LED fixtures!
Fred
acstokes is offline   Reply With Quote
Old 11-27-2013, 08:00 AM   #20
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
well, I will first try pushing a bit harder....did not push all that hard the first go round due to being a bit timid....will try that again...
Ill be interested to see how these keep moisture out....I am not sure I want to waste any time/money sealing up these fixures as they are cause I think these gaskets are going to be a problem...hope not, but time will tell...and we have heard from a couple people describe them as a problem...and they are more problematic to keep right and repair in the long run I would think...if they have problems within the warranty period, JC will replace them I would think...
Need to fix this one and just keep watching them...
Good point on LED's...I did not think about the heat difference with incandescant vs LED...
The atoms of our bodies are traceable to stars that manufactured them...We are not figuratively, but literally stardust.
PharmGeek is offline   Reply With Quote
Old 11-27-2013, 08:01 AM   #21
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I asked this before, but what is that grey sealant above the awning rail...I want to patch a gap I see there soon.
Old 11-27-2013, 08:09 AM   #22
Thumbs up
This is a good choice....
PFC
"Tahawus"
RLC
John Prine
Old 11-27-2013, 08:16 AM   #23
Howard L.'s Avatar
San Antonio , Texas
Originally Posted by PharmGeek View Post
I asked this before, but what is that gray sealant above the awning rail...I want to patch a gap I see there soon.
Perry told you above: "" Parbond is for thin cracks and Trempro-635 is for fat cracks ""
Also Acryl R , and it is the thinnest. So I bet it's probably the Trempro above the awning. You can order a caulk kit from JC that has the Acryl R and Trempro plus a couple others for use on the trailers " different colors for different areas." Order ParBond elsewhere.
Old 11-27-2013, 08:28 AM   #24
aftermath's Avatar
Spokane , Washington
FWIW, our dealer says to use Sika-Flex. I have used it to redo the seams, it is gray and is holding up well. Above my awning, where it attaches to the trailer, they used a white compound. It is now getting rather old and my plan is to clean it off and reapply new stuff this summer. I was told to use the same stuff.
aftermath is offline   Reply With Quote
Old 11-27-2013, 09:46 AM   #25
2016 30' Classic
Erie , Colorado
Why not send a question to the factory? Or your dealer?
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 11-27-2013, 04:29 PM   #26
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Get Jackson Center on the horn. They are very helpful.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-27-2013, 05:20 PM   #27
1981 31' Excella II
New Market , Alabama
The clearance lights I bought off of ebay have the LED's potted in epoxy so no moisture can get to the electrical connections. Moisture does get under the lens though but I don't worry about it. I have not seen many lights that don't leak unless the lens is glued to the base.
Perry
Old 11-27-2013, 07:07 PM   #28
m.hony's Avatar
2013 30' Classic
That is comforting- all of mine on the curb side have moisture under the lenses. I don't think water/moisture can enter the trailer this way, either- at least that's what Jim at Foley led me to believe.
TAC #MS-10
Airforums #70955
Repair project - my 2005 30' Classic wingfooted General Repair Forum 6 07-24-2011 06:16 AM
Running light won't turn off terryd Lights - Interior & Exterior 4 07-20-2011 07:41 PM
looking for help with Magic chef oven pilot light jayg Stoves, Ovens & Microwaves 2 06-01-2011 04:18 PM
Replace Tail Light Bezel on 1971 Safari pickerdd Lights - Interior & Exterior 2 05-31-2011 07:20 PM
Replace clearance lights Okiegent Lights - Interior & Exterior 0 03-04-2011 08:43 PM
