Old 03-13-2011, 10:47 AM   #1
Teray's Avatar
1966 30' Sovereign
Graham , Alabama
Images: 16
Need Light Bulbs '66 Soverign
We are looking to find out what the replacement bulbs are for a 1966 soverign, need break light replacement bulbs, and where to purchase today
Teray is offline   Reply With Quote
Old 03-13-2011, 10:53 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
If I remember correctly It's 1157 duel filament.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-13-2011, 10:57 AM   #3
Teray's Avatar
1966 30' Sovereign
Graham , Alabama
Images: 16
do you know where the men might find these bulbs,
Thank you in advance
Teresa
Old 03-13-2011, 10:59 AM   #4
1967 22' Safari
1960 Caravel
Images: 8
Teresa
Any auto parts store. It's very common.
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 03-13-2011, 11:00 AM   #5
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Teresa
Any Auto Parts store.
Colin
Colin H is offline   Reply With Quote
Old 03-13-2011, 11:22 AM   #6
Teray's Avatar
1966 30' Sovereign
Graham , Alabama
Images: 16
Hi again, Just passed this info on they tried an 1157 bulb last night and it would not lock in. The light has the following info on the lights on the camper, is this is any help in determining the current bulb type, thanks very much for all of you quick and helpful support.
Auto Lamp 576
SAE -S-1a-l-t-63
Teresa
Old 03-13-2011, 11:28 AM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Another option.
Does the socket have one or two buttons at the bottom? If it has one; an 1156 should work. If it has two an 1157 should work, but the pins are offset on the 1157 and you need to orient the bulb accordingly. Both should be available at any auto parts or even Wal Mart.
Old 03-13-2011, 11:30 AM   #8
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
The single filament version of that size is an 1156 & the double is 1157 however there are different wattages out there with different numbers. Take to old bulb to the Auto Parts store & they should be able to match it up.
Colin
Old 03-13-2011, 11:33 AM   #9
1967 22' Safari
1960 Caravel
Images: 8
1156 is a good option. Does this light have two sockets in the assembly?
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 03-13-2011, 11:34 AM   #10
Teray's Avatar
1966 30' Sovereign
Graham , Alabama
Images: 16
no BULBS
There were no bulb in the camper back area.
Old 03-13-2011, 11:36 AM   #11
1967 22' Safari
1960 Caravel
Images: 8
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 03-13-2011, 12:18 PM   #12
Teray's Avatar
1966 30' Sovereign
Graham , Alabama
Images: 16
The camper has NO light bulbs the tail lights, someone had taken them out and that is what is making it hard to find light bulbs
Old 03-13-2011, 01:40 PM   #13
1967 22' Safari
1960 Caravel
Images: 8
Did you try 1156 bulbs yet?
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 03-13-2011, 02:31 PM   #14
Teray's Avatar
1966 30' Sovereign
Graham , Alabama
Images: 16
Ok, daylight and rested up, they took a fresh day to start over on the wiring issue and found bulbs, all is well, we have lights and brakes, they are south bound and down with the Magic Carpet Ride. About 3 hours she will be home.
Again I want to thank each and every one for comments, help, ideals, and support. We are new to the AS world, but we are hooked and she isn't home yet.
Ray and Teresa
Alabama
LED light kit for the Monarch stop tail and turn light Dan@LED4RV Commercial Listings 5 05-12-2014 05:05 AM
Running light bulbs.. goshawks00 Lights - Interior & Exterior 2 09-07-2011 12:11 PM
Replace Tail Light Bezel on 1971 Safari pickerdd Lights - Interior & Exterior 2 05-31-2011 07:20 PM
light bulbs in 2004 classic? art Lights - Interior & Exterior 2 03-03-2011 05:33 PM
Flash of Light !! donking General Repair Forum 8 01-24-2011 02:16 PM
