Old 12-25-2008, 05:21 PM   #1
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant , South Carolina
Need help with Mystery Switch in 1988 Limited
Hey guys,
Have a 1988 34' limited with a 120v switch inside the cabinet above the stove (next to the door) that I have no idea what it controls. Nothing seems to not work when it is off--a complete mystery.
It has one (looks like #10) wire coming out of the bottom of the box and two (#10) wires coming out of the center of the box. I can see this by removing the hood vent screen. The three wires disappear into a hole in the interior aluminum and it appears to be original since the hole in the aluminum has one of those plastic 'protectors' that match the rest in the trailer.
Any ideas?
Bill
Cantrell is offline   Reply With Quote
Old 12-25-2008, 05:24 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Ours has a switch that enables you to run the microwave or roof air.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 12-25-2008, 05:50 PM   #3
willyd's Avatar
1993 34' Limited
Melbourne Florida , Springfield Ohio
I agree with Mike - we have the same switch that enables either the ac or micriwave, but mine is over the sink. Take Care
willyd is offline   Reply With Quote
Old 12-25-2008, 06:35 PM   #4
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Thank you both. I guess I need to get inside the box to see if it has power because it has no effect on either the microwave or the A/C unit.
Begs the question--why would you need another switch to control power to the A/C or the microwave?
Bill
Old 12-25-2008, 06:42 PM   #5
Mike Leary's Avatar
Images: 11
Originally Posted by Cantrell View Post
Begs the question--why would you need another switch to control power to the A/C or the microwave? Bill
They both take a ton of juice and cannot be run at the same time, hence the switch.
Old 12-25-2008, 06:43 PM   #6
Forrest's Avatar
1986 32' Excella
Aurora , Colorado
Images: 21
The switch is to prevent overloading the circuit breaker by running the A/C and Microwave at the same time. Singly there's no problem, but together they might draw more than 30 amps. If your switch doesn't close the circuit to one or the other it might be because a previous owner bypassed it, or perhaps your breaker box and shore line have been upgraded to 50 amp?
Forrest
Out for coffee!
Forrest is offline   Reply With Quote
Old 12-25-2008, 06:45 PM   #7
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
If you have the original microwave and AC it will limit the use to one or the other, so you won't blow a fuse. It may well have been changed over the years.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 12-25-2008, 06:51 PM   #8
Mike Leary's Avatar
Images: 11
I don't get it; how is that possible? I thought all coaches came with the switch.
Old 12-25-2008, 07:03 PM   #9
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Changed by a previous owner not Airstream. Anything is possible from a previous owner.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Mystery Switch jagcb750 Classic Motorhomes 54 10-09-2011 11:50 AM
Switch Mystery excella1976 1975-1976 Excella 500 2 01-26-2008 08:06 AM
Mystery toggle switch mpumphrey04 Electrical - Systems, Generators, Batteries & Solar 9 12-07-2005 07:47 AM
Differences..Classic <vs> Limited..1988 to 1999 route66 Full-Timing 7 04-25-2005 05:05 PM
