Old 08-01-2016, 11:05 AM   #1
1969 31' Sovereign
Brunswick , Maine
need help identifying a exterior light (?) for 1970 Sovereign
Hi,
I'm renovating a 1970 Sovereign. On the exterior, on the side but close to the end, there is a light (?) that appears to have two small red LEDs (?). The housing for this rotted away; I'm trying to determine its function and replacement part. Photos attached...
Also, above the front door there is a light fixture, but no 'guts' to it. What type of socket/fixture should I install here? (more photos attached).
Thanks so much for any advice anyone may have!!
Mark (Maine)
ID:	268095   Click image for larger version
ID:	268097   Click image for larger version
northwoods is offline   Reply With Quote
Old 08-01-2016, 12:40 PM   #2
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Not Lights!
Originally Posted by northwoods View Post
Hi,
Mark (Maine)
Mark, Those two Lights are Fiber optic sensor to let you know if your rear taillight/brake light bulbs are working and lit! The cover in most instances was plastic but you can fabricate a new one out of aluminum. Over the main cabin door is a porch light fixture. It should be 12 volt fixture and an aluminum cover over it. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 08-01-2016, 12:47 PM   #3
1969 31' Sovereign
Brunswick , Maine
Thanks!!
Thanks so much Ed, mystery solved!! I'll check that out when I try to get the tail lights running & try to make some sort of decent-looking installation for it. Its a great idea - I wish cars had some sort of sensor to tell you when you've for a tail light out - new invention? !!
sovereign
Need help identifying RM model fridge happygrrly Refrigerators 17 08-29-2009 11:33 AM
Need help identifying black tank in floor. zipman Repairing/Replacing Floor &/or Frame 4 05-17-2009 10:15 PM
I need help identifying these rims NatchezBear Wheels, Hubs & Bearings 4 11-02-2008 06:31 PM
Need help in identifying this Airstream JimGolden On The Road... 10 01-01-2007 01:56 AM
Need help identifying old Airstream! KY Girl Our Community 3 12-12-2002 06:16 PM
