Old 09-29-2011, 07:02 AM   #1
1976 27' Overlander
Elkhart , Indiana
Need a replacement light switch-any ideas?
The switch for the overhead lights at the twin bed area of our '76 Overlander has gone kaput. It is a round knob controlling a 6 bulb 3 way fixture. Any suggestions on where to find a replacement? I'm kinda new to the forums. Knob is intact just the switch is fried. Is there anything we need to check in the wiring to make sure we don't fry the new switch? Thanks.
wannanair is offline   Reply With Quote
Old 09-29-2011, 07:13 AM   #2
x
XXXX , XXXX
Inland RV Center Inc.
It's usually the contacts in the switch that wear out. The wiring is probably fine unless you are blowing fuses then you have a short circuit.
wasagachris is offline   Reply With Quote
Old 10-05-2011, 08:34 AM   #3
In time, those switch contacts wear.
You can check the other switches out by turning all 6 bulbs on.
After about 10 minutes, "gently" turn the switch knob "backwards".
If that causes the lights to flicker, then that says that switch has reached it's useful life, and should also be replaced.
Those switches are special to Airstream, and can be obtained from parts stocking dealers.
Old 10-24-2011, 08:54 AM   #4
2006 16' International CCD
Castle Rock , Colorado
Can a 2 circuit 3 way switch for house lamp be used on a 1960's tradewind ceiling light?
Miss Vicki is offline   Reply With Quote
Old 10-24-2011, 09:05 AM   #5
Yes.
Old 10-24-2011, 09:14 AM   #6
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
This might work Vintage Trailer Supply Airstream Rotary Switch
Bill
Just my personal opinion
Old 10-24-2011, 12:40 PM   #7
switch
The switch on Vintage Airstrean Supply has too long of stem for mine my application. Thanks
Overhead Light Switch "HI-LIGHT-LO" motilley Lights - Interior & Exterior 14 08-23-2017 06:11 AM
I want my water pump switch to light up... Friday Electrical - Systems, Generators, Batteries & Solar 18 09-18-2011 10:03 PM
Replacement over the counter light ??? polarlyse Lights - Interior & Exterior 2 07-05-2011 03:00 PM
2006 Safari Interior light switch Goal15 Lights - Interior & Exterior 7 05-03-2011 01:36 PM
Replacement Gold Cone Light for '58 mello mike Lights - Interior & Exterior 7 03-17-2011 10:56 PM
