Old 05-19-2017, 07:29 AM   #1
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Mystery switch
Anyone know what the switch above the door does?Click image for larger version
BambiTex is offline   Reply With Quote
Old 05-19-2017, 08:07 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Possible fridge vent fan or outside scare light.
MICHAEL
Old 05-19-2017, 08:30 AM   #3
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Switch to left of window is for scare light No fridge fan...
Old 05-19-2017, 12:15 PM   #4
NO HUMBLE OPINION
ALUMINUMINUM's Avatar
1968 20' Globetrotter
ANN ARBOR , THE GREAT LAKES
1968 “Switch by the Door” vs Cabin Rotary Switch Mystery
I don't know all the models and years that this occurs in, Maybe only '68GTs? It may bother no one but me...
What sense is it to have redundant ON-OFFs? The switches are not wired three-way, and within an arm's reach of each other without taking a step?? The switch by the door does nothing unless the center cabin light is already switched to one of its three ON positions. Can anyone find logic in this? There's no reality where wiring through two switches for one light makes sense. It is an unnecessary annoyance.
What to do, other than removing the switch, and connecting the wiring behind it to always be ON, and having a cover plate there, so the cabin light operates normally with its rotary switch?? Could put tape over it and mark do not touch?? It's frustrating to dial the cabin light ON, only to find that the door switch is in OFF position, then turn door switch to ON, then dial cabin light to desired intensity of one bulb, two bulb, four bulb or OFF.
If the switch by door is there for night entry, It only works if you remember to turn the cabin light ON and the door switch to OFF when leaving. You think this is confusing and annoying to read? Try it in real life with both hands in the dark. It's really stupid, and further exacerbated by the horizontally door mounted switch, so you cannot intuitively switch Up-ON, Down-OFF.
This was driving me nuts. I thought maybe the switch was there for the optional front vent fan motor that my trailer didn't have, but that option, the fan switchis located next to the fan, same as the aft vent fan. No, it's not for the scare light, or wired to the kitchen light, no step light option.
Here's what I did to ease my sanity about this irritating nonsense…
The original equipment:
The rotary switch, centered in the cabin light, offering four positions,
1-One bulb
2-Some bulbs
3-All bulbs
4-OFF
The single throw single pole household residential on-off wall switch by the door mounted horizontally, Grrrrr
Their replacements:
Two, $5 ON-OFF pull-chain switches from the hardware store.
One switchplate cover, drilled for pull-chain switch
One Rubber Ducky
I replaced the “switch by the door” with a pull-chain switch, and “DUCK!” reminder.
I wired the ”DUCK!” switch so that it controlled only one of the four lamps in the cabin light. The remaining three warm 1141LEDs* are simultaneously controlled by a single pull-chain switch which replaced the original rotary multi-position switch. Now, the cabin light switch operates independently from the “DUCK!” door switch. The “DUCK!” switch is perfect for night entry, or provides “mood” lighting. The “DUCK!” switch can, of course, be ON along with cabin light to provide all four bulb illumination.
This is an inexpensive, practical, Calming solution…
No Cost Alternative,
For the all original look, you can keep the residential style “switch by the door” as is, if you can tolerate its horizontal orientation, as all the wiring is right behind the cabin light, and easily rewired as explained. You can also rewire to keep the original rotary switch.
At 6ft, I need to duck, hence the reminder. Entering the trailer at night, I can pull the chain before stepping inside…. Mellow...
About those original rotary light switches, you don't need to buy new ones. If you pry the tabs back, you can access the innards, and clean the contacts. The VTS “replacement” switches that I purchased do work, but they're a little too long and will not accept the original rotary knobs. I changed all the overhead rotary switches to single pull chains, it's easier for me to reach up and pull the chain ON-OFF than to rotate the switch.
*You can buy a ten-pack of these from eBay for $8, shipped in a week, or pay Airstream $$$ retail for the same repackaged bulb
ID:	285868   Click image for larger version
ID:	285870   Click image for larger version
ID:	285872   Click image for larger version
ALUMINUMINUM is offline   Reply With Quote
Old 05-26-2017, 09:11 AM   #5
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Mine does nothing
As far as I can tell my horizontal above the door switch does absolutely nothing. While this is somewhat annoying to one slightly afflicted (as I am) with OCD, I am not sufficiently bothered to dismantle the inner skin and follow the wires:-)
Old 05-26-2017, 11:41 AM   #6
Mollysdad's Avatar
There's a device the phone guys use (and others who need to trace wires) called a "tracer". It's comprised of two parts, a tone generator that makes a warble to alligator clips, and a sniffer that listens to wire through the insulation. You clip on the tone at one end and sniff any other wires you have access to, the one with the warble is it!
Mine has saved me hundreds of times, often a mile away on telco wires.
Old 05-26-2017, 11:57 AM   #7
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Mystery Switch.....
Try This.... In my '67 Safari if you turn the light on over the galley sink then the Mystery Switch over the door turns that galley light on and off as you leave or enter the trailer. Does this work in your situation? Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 06-07-2017, 11:00 AM   #8
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
No such light
I do not have a factory light over the sink, though it would be nice to have one. I added under-cabinet LED lighting myself, controlled by local switches.
Mystery Switch jagcb750 Classic Motorhomes 54 10-09-2011 11:50 AM
'89 Excella 25 mystery switch? Pix attached also... BillTex 1987 - 1989 Excella 12 05-22-2011 01:05 PM
Switch Mystery excella1976 1975-1976 Excella 500 2 01-26-2008 08:06 AM
Mystery toggle switch mpumphrey04 Electrical - Systems, Generators, Batteries & Solar 9 12-07-2005 07:47 AM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
