01-11-2012, 07:09 PM
Biloxi
, Mississippi
Mystery outage
I have a mystery outage with my Bambi II that has me stumped. While waiting for my house to have a 30 amp line dropped I have been using a 30 to 20 amp plug to run the lights and fridge. Everything has been working fine. This morning I went to swap the extension cord out that that I was using for a shorter one. Swapped and plugged the new one in. The GFCI plug blew in the garage. I reset the breaker and it blew again. Went back out the trailer flipped the power back to the battery and started to make sure that everything was still working. On board breakers are fine. Everything worked except a light over the sink and of course the AC plugs. Visually checked all the wiring and connections that I could get too and all looked ok. I have tried the AC with 3 different extension cords with no change. Any ideas?
01-11-2012, 07:51 PM
1995 30' Excella
Logan
, New Mexico
Do you have a plug that doesn't have a gfci breaker installed on it. Try plugging it into that plug.
Charles & Annette
WBCCI # 1407 -- Member 4CU
1995 31' Excella
Dodge 2500 Diesel-Tow Vehicle
___________________________________________
01-11-2012, 08:12 PM
1978 31' Excella 500
Venice
Sounds like the second cord is defective. Use the first one.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
01-12-2012, 05:01 AM
Biloxi
, Mississippi
Nope, all my plugs are GFCI protected.
As I said in the OP, I have tried 3 different cords, all with the same results.
01-12-2012, 05:10 AM
2002 25' Safari
Fountain Inn
, South Carolina
You may try the power outlet with a lighter load like a blow dryer and see if the GFI trips. Your GFI may have reached the end of life.
The GFI on the outlet I use for my trailer suddenly started tripping. A new GFI solved the problem.
01-12-2012, 05:13 AM
1995 30' Excella
Bowie
, Maryland
RVs trip GFCIs frequently. If you search around, you'll find a couple topics on the issue. Sometimes you can trace it to a specific cause, like a wiring problem in the camper itself, but even that can be difficult to find. Ours trips our GFCI outlet too (annoying, considering it's mounted about 5' from the trailer!), and it does so randomly - we haven't yet figured out what causes it to suddenly trip, though I admit I haven't spent much time figuring it out - I just run an extension cord to an outlet that doesn't have this issue.
I think this is why RV outlets (the 30 amp versions) are not GFCI protected.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
01-12-2012, 08:43 AM
Biloxi
, Mississippi
I will have a 30amp extension cord waiting for me when I get home this evening. It will be able to reach the 30amp outlet I had installed yesterday. Hopefully that will do the job.
This is starting to be almost as much fun as boat ownership.
01-12-2012, 06:00 PM
Biloxi
, Mississippi
Well it is still a mystery, but it is fixed. I got my 30 amp extension cord today. Plugged it in and everything works just as it is supposed too. All lights, AC plugs and AC work just fine. Life Is Good!!
01-12-2012, 08:01 PM
1974 Argosy 26
Morrill
, Nebraska
I believe it is because now the power source is not on a GFI breaker. I would suggest that you still do a thorough check out of the electrical system in your trailer. Confirming that the "hot leg" the "neutral" and the ground of the AC system is wired correctly.
There are a number of web sites that can help you with the process. Just type in RV electrical.
01-13-2012, 12:46 PM
Biloxi
, Mississippi
Twinkie, definetly will get back to it but right now moving on to other projects, such as getting the hot water heater to fire up. One project at a time.
01-13-2012, 01:34 PM
Wise Elder
2010 30' Classic
South of the river
These problems are nearly always caused by a short between ground and neutral. Sometimes in older trailers someone did that deliberately. It's not safe and should be corrected even though you have the new outlet to use.
01-13-2012, 02:17 PM
Biloxi
, Mississippi
When ever I take a look around some hidden compartment I find wires twisted together. Some are taped (usually the tape is all dried out and falling off) and some are just bare wires (tape has already fallen off - scary). I have been keeping a pocket full of twist connectors close just to reconnect them as found. I would not at all be surprised if there is a short to ground somewhere.
