Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 05-29-2009, 05:20 PM   #1
Profile:  1966 30' Sovereign
1963 22' Safari
orlando , Florida
Images: 8
mysterious electrical problem
With the change in the Florida weather lately,so too surfaced an electrical mystery(at least to me).The weather had been of low humidity for weeks and then the rains commenced to flooding situations in some areas of the state.When the rains came ,so did the mystery.One breaker would trip.The other remained functioning just fine.After a short panic,no electrical pun intended,I remembered that waiting and doing nothing ,the problem may FIX itself.It did.The clouds moved on and so too my lack of power in half the trailer, until it rained again! Being a bit more aggressive and cautiously noting it was an electrical problem and one not to be taken lightly ,I acted.I took a breeze! A breath of fresh air that is, for the '63 Safari.Opening the trunk space and giving the 46 year old breaker box some air to dry out is working.Any thoughts,suggestions? They don't have to be water tight.
richie rich is offline   Reply With Quote
Old 05-29-2009, 05:28 PM   #2
silverleeper's Avatar
Profile:  1967 22' Safari
1960 18' "Footer"
Edmonds , Washington
Water is a conductor. If water gets between exposed circuit and ground this will cause a short and the breaker will trip. So, Yes it helps if there water tight. Take a look in the box for any exposed wet wires.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 05-29-2009, 06:55 PM   #3
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
It may not be a breaker, you may have a wire that the increased moisture is causing a ground. If you have an electrician friend, maybe he can bring over his tone-trace equipment, and track it down for you.
Old 05-29-2009, 10:05 PM   #4
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Correction: Pure water is not a conductor. Most water has impurities. These are the conductors. That said.
A water leak is still a problem.
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://Michelles-Adventures.US
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Old 06-28-2009, 04:39 PM   #5
1963 22' Safari
orlando , Florida
Images: 8
mystery solved! It was a dead short from an outside electrical socket.Water made it's way past the weatherproof cover.The inside of the receptacle was wet,corroded,and disintegrating.The outside screws broke off in my hand.What helped was feedback from forum members.Someone mentioned how the circuit was daisy chained like christmas lights.The short being located in that chain.After seeing the circuit breaker box was good,I checked outlets.The exterior ones being most susceptible to water were first and the problem.Thank you for the response.
Electrical problem Dr JJ 1965 Globetrotter 3 06-17-2008 01:13 PM
electrical problem David Hall Electrical - Systems, Generators, Batteries & Solar 7 12-31-2003 09:46 PM
electrical problem kent osborn 1966 - 1968 Safari 3 09-27-2003 06:30 AM
AC electrical problem lbf78SvgnInt31 Electrical - Systems, Generators, Batteries & Solar 2 07-26-2003 07:44 PM
HELP! Electrical problem FranceyS Electrical - Systems, Generators, Batteries & Solar 4 11-11-2002 06:27 PM
