Old 06-28-2010, 02:51 PM   #1
azfiredog300's Avatar
Surprise , Arizona
More brake light problems
I'm about to embark on a trip from Phoenix to Northern California and I have encountered a problem. My brake lights, turn signals and hazard lights work fine during the day but at night while my lights are on when I hit the brake the right brake light goes out. I also noticed that the light itself is more dim than the left. I checked at the brake light for shorts and found none, I also checked at the pigtail which also seems to be complete circuits. I did realize that the PO did some creative wiring which you will see in the pictures. At this junction I have checked to make sure that all circuits are complete but I am unsure of what the little black circuit is for. Any ideas on my problem?
ID:	105845   Click image for larger version
Jerry C.
"Travelstar Galactica"
WBCCI #13317
AIR #25664
Member of the Four Corners Unit
The only true failure is the failure to try.
azfiredog300 is offline   Reply With Quote
Old 06-28-2010, 03:05 PM   #2
Surprise , Arizona
Could this problem be at the Univolt? Cuz I hear a hum when I hit the brake.
Jerry C.
WBCCI #13317
AIR #25664
Old 06-28-2010, 03:31 PM   #3
Mexray's Avatar
1978 28' Ambassador
Morada , California
Sounds like a 'ground' problem - when a light is dim, it's usually a bad ground connection - that could also cause some other strange outages...
check the socket itself, to make sure the bulb is getting good contact on the center contact, and the socket itself, which is the actual 'ground' connection...
Also then check bot the leads from the socket to their next contact point - our AS has a bunch of connections in the rear for the tail/stop/backup lights...something could be loose...
If that fails, check around the fuse panel where the wiring has been modified...
I don't like to see those 'twist connectors' for 12 volt wiring - they can be disconnected too easily - use some crimp but connectors and get rid of those yellow twisters...
Bad ground connections cause some strange things with the light circuits....
Ray
Ray & Pat; Morada, CA
Old 06-28-2010, 04:23 PM   #4
Surprise , Arizona
Thanks MexRay, I'll give that a check
Jerry C.
WBCCI #13317
AIR #25664
Old 06-28-2010, 04:54 PM   #5
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
When you apply the brake, the hum you hear is most likely the electric trailer brakes activating.
Brian
SuEllyn & Brian McCabe
Old 06-28-2010, 04:57 PM   #6
Surprise , Arizona
Duh, sometimes the most obvious eludes me. Thanks Moose
Jerry C.
WBCCI #13317
AIR #25664
Old 06-28-2010, 04:59 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
The creative wiring isn't it. You have a bad ground on the right brake/turn lamp assembly.
Old 06-28-2010, 05:01 PM   #8
Surprise , Arizona
How do I find where the bad ground is?
Jerry C.
WBCCI #13317
AIR #25664
Old 06-28-2010, 05:19 PM   #9
Wise Elder
Jammer's Avatar
2010 30' Classic
Take the tail light out and clean the ground wire and be sure it's screwed down tight when you put it back together.
Old 06-28-2010, 05:23 PM   #10
Surprise , Arizona
I'll give that a try, thanks
Jerry C.
WBCCI #13317
AIR #25664
Old 06-28-2010, 08:16 PM   #11
Surprise , Arizona
could it be the bulb itself?
Jerry C.
WBCCI #13317
AIR #25664
Old 06-28-2010, 09:09 PM   #12
Splitrock's Avatar
Sioux Falls , South Dakota
I have three utility trailers I tow and every spring I start over with lights. The way I check to see if the ground is bad is to test the ground with a jumper wire grounded to the frame in a clean way. I test the jumper with a resistance meter. If the light works bright with the jumper, I usually just end up running a new ground to the frame. Sometimes just relocating the ground will work. I seldom find a bad wire. It's usually the ground contact point that's the problem.
With clearance lights, I just replace the fixtures when I have to service one. With the tail lights and break lights, sometimes the light fixture has a bad socket. Those should be replaceable. Your dim light tells me it's the ground.
Old 06-28-2010, 11:03 PM   #13
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, like everyone else, it sounds like a bad ground at that light.
(1.) Connect a wire to a solid ground and hold the other end to the base of the light socket/housing; It should make the light brighter. [if it is a bad ground]
(2.) Use a test light, connecting the clip to a good ground and touching the point of the test light to the light socket base/housing; If the light gets brighter or the test light, lights up, you have a bad ground.
(3.) Somewhat rare, but I have had them, An internally grounded bulb or a dual filament bulb where one filament has broken on one end and has dropped and is touching the second filament.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 06-28-2010, 11:38 PM   #14
Surprise , Arizona
thanks much for the info, got my work cut out for me tomorrow.
Jerry C.
WBCCI #13317
AIR #25664
Trailer brake problems WK57ABF Brakes & Brake Controllers 67 10-19-2010 09:02 AM
77 disc brake problems tschat Brakes & Brake Controllers 10 06-22-2007 12:35 PM
Brake problems hummerdinger Brakes & Brake Controllers 12 07-19-2005 02:00 PM
Brake Problems 1985 Sovereign GRAYMAN Brakes & Brake Controllers 3 05-26-2005 10:50 AM
