Old 06-29-2010, 01:27 PM   #15
azfiredog300's Avatar
Surprise , Arizona
OK, I finally figured it out. So here is a little tidbit for those, who like me, that like to take the long way to a short solution. The bulb socket appeared to be fine on the outside so I (ass-u-me-d) that it was ok. However, after following all "common sense" attempts to fix I finally took the wiring out of the socket to find that the inside was rusted almost completely. Thus, after replacing the socket "vuala" it works. Thanks for all the helpful hints, and with those I am now a smarter electrician. Man I love these forums.
Jerry C.
"Travelstar Galactica"
WBCCI #13317
AIR #25664
Member of the Four Corners Unit
The only true failure is the failure to try.
azfiredog300 is offline   Reply With Quote
Trailer brake problems WK57ABF Brakes & Brake Controllers 67 10-19-2010 09:02 AM
77 disc brake problems tschat Brakes & Brake Controllers 10 06-22-2007 12:35 PM
Brake problems hummerdinger Brakes & Brake Controllers 12 07-19-2005 02:00 PM
Brake Problems 1985 Sovereign GRAYMAN Brakes & Brake Controllers 3 05-26-2005 10:50 AM
