Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 06-09-2008, 07:27 PM   #1
jdalrymple
jdalrymple's Avatar
Profile:  1981 31' International
Siloam Springs , Arkansas
Monarch LED Conversion
Hello All.
I have searched the forums, and looked at most of the sources recommend, but can’t seem to locate a LED upgrade/replacement for my Monarch square tail/back-up lights. Any suggestions?
Thanks in advance for any help.
Jeff, Cindy and the Brittanys:
Remi and Hunter
'81 International 31'CB "Fus-a-lodge"
'03 2500HD Chevy Duramax w/improvments
WBCCI #7026 Air #17054
Old 06-09-2008, 08:10 PM   #2
DIMMER
Vagabond
DIMMER's Avatar
Profile:  1973 31' Sovereign
Semi, Pro Rock Crawler , Motorsports Photographer
Are yours like mine?? In the next week I will be upgrading to the new bezels so I can go led!!!
ID:	62112  Click image for larger version
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
DIMMER is offline   Reply With Quote
Old 06-09-2008, 08:13 PM   #3
DPeakMD
DPeakMD's Avatar
Profile:  1975 23' Safari
1978 31' Excella 500
Franklin , Indiana
Dimmer, was your 3rd brakelight standard issue, or did you add it on?
Dallas
WBCCI/VAC #8481
AIR #9
W9CDC
DPeakMD is offline   Reply With Quote
Old 06-09-2008, 08:24 PM   #4
RivetED
RivetED's Avatar
Profile:  2005 25' Safari
Hillsboro , Texas
There are 2 options for those type taillights without any major rework. A 90 degree 1157 with 30 leds and a pcb with 24 or 36 leds on an 1156 base. I bought mine from superbrightleds.com. The pcb mounted leds (I went with the 36-led wide-angle option) are intended for internal boat/rv use. I'll post pics and a review when installed, this week I hope. The pcb unit will be tried on my back-up (1156) lights just for kicks, if it works I'll buy some more, otherwise it'll go in the bath-room where the 4 incandescent bulbs can dry your hair if there was a blower attached!!! BTW: Buy the red leds if they are going behind a red lens, that way 100% of the light will be visible or else if you go white only the 'red' portion of that light will actually get beyond the red 'filter'/lens!
"I have a new invention, 'Instant Water'. I don't know what to add to it!"
RivetED is offline   Reply With Quote
Old 06-09-2008, 08:30 PM   #5
DIMMER
Vagabond
DIMMER's Avatar
You like that don't you!!!!! It had to be oem, do to the rivets on the sides. It also works as a turn signal. But its the only one I have ever seen. But they have a replacement part in the parts department at the Mother Ship JC. DIMMER
Old 06-09-2008, 08:45 PM   #6
Dwight
Dwight's Avatar
Profile:  1999 34' Excella
Joshua , Texas
Try this link...
LED Taillight upgrade
History doesn't repeat itself, people do!
Dwight is offline   Reply With Quote
Old 06-09-2008, 09:08 PM   #7
Mexray
Mexray's Avatar
Profile:  1978 29' Ambassador
Stockton , California
My Monarch LED 'conversion' was much easier than the one linked in the post above...take a look here:
http://www.airforums.com/forums/f173...0-s-42187.html
Go to a Trucker's supply that has LED stuff and check out their lights...you'll probably find something real close like I did.
Let us not be too particular;
it is better to have old secondhand Airstreams than none at all.
Mark Twain, updated
Mexray is online now   Reply With Quote
Old 06-10-2008, 07:50 AM   #8
jdalrymple
jdalrymple's Avatar
I do like it. Thanks for all the great info. Your AS looks great, too!
Remi and Hunter
Old 06-10-2008, 08:00 AM   #9
jdalrymple
jdalrymple's Avatar
DIMMER,
Mine do look like yours. Why new bezels? Are there no direct replacement LED parts available?
Remi and Hunter
Old 06-10-2008, 08:16 AM   #10
DIMMER
Vagabond
DIMMER's Avatar
When the polish and new clear coat was done. I had the new trim and badges added. So now I'm going to add the new bezels and led tail lights. That Is, If I can make them work!!! DIMMER
Anyone done an LPG conversion? Boom Sounds Classic Motorhomes 14 07-04-2008 04:47 PM
LED tail light conversion Pahaska Electrical - Systems, Generators, Batteries & Solar 137 05-08-2007 02:06 AM
led conversion bubbainsd Electrical - Systems, Generators, Batteries & Solar 3 11-01-2006 06:27 PM
LED conversion of exterior lights HowieE Electrical - Systems, Generators, Batteries & Solar 0 07-13-2006 06:07 PM
AC conversion jaiman Mechanics Corner - Engines, Transmission & More... 9 09-04-2003 03:22 PM
