Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 04-02-2008, 12:04 PM   #1
Royce
Royce's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
Colorado Springs , Colorado
Minuet LED light design
I decided to design and build new interior lights for the Minuet. LED was a must as we like to Boondock and want low current drain on the battery. I also wanted to salvage the original light switch as it is a four position. The light for the galley pictured here has 8 of the 6 LED light strips from Superbrights. I connected 3 on position one 5 on position two and all 8 on position three of the switch. Initial testing with 3 total didn't provide sufficient light. For the bath room I will use 4 or 6 of the light strips and 6 or 8 for the dinette light. The body is rock maple hollowed out in the back for the wires and the lens is 1/8" acrylic, this fixture used 2 of the warm and 6 of the cool white. Warm white is far too yellow and the cool is too cold. The combination works for a nice balance to my eye. I will follow up with photo after installed, but have some interior work to do first. Left hand photo is the lens side and the right photo is of the back side. Paper dust cover in place, not sure if I will worry about that in the future renditions.
ID:	57455  Click image for larger version
Royce (K0RKK) and Karen
AIR# 3913
Royce is offline   Reply With Quote
Old 04-02-2008, 12:06 PM   #2
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
I'll look forward to the finished product.
Dave
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 04-02-2008, 01:13 PM   #3
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
Not that I would ask you to rip it apart but do you have any photos of the lights inplace without the lens?
Do you have a site for Superbright?
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
HowieE is online now   Reply With Quote
Old 04-02-2008, 01:29 PM   #4
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
I have also been looking for new interior lights. Did you roll the lens too, and if you did where did you find the milky colored acrylic? i have not been able to find LED fixtures that Liked.
Old 04-02-2008, 02:27 PM   #5
UpNorthAir
UpNorthAir's Avatar
Profile:  1970 31' Sovereign
Horton Bay , Michigan
What size LED's did you use? I found these on ebay and was thinking of using them like you did. Just don't know how many to use... Maybe these could be used as recessed lighting in the ceiling? hmmmm
WHITE HIGH Power LED Aluminum Pod Module 1 Watt light - eBay (item 180132124603 end time Apr-14-08 13:08:04 PDT)
Nice job!
UpNorthAir is offline   Reply With Quote
Old 04-02-2008, 03:54 PM   #6
HowieE
HowieE's Avatar
Images: 11
If you are considering LED lights and want to make up your own fixtures take a look at this site. Good info.
Sample LED circuit designs.
Old 04-02-2008, 05:22 PM   #7
Royce
Royce's Avatar
Aerowood,
The lens is 1/2 of a 4" clear acrylic pipe. Masked off the cut area and the side against the fence and cut on a table saw. I used the same trick to frost it as the big boys use to frost the view glass on a large format camera, 220 grit sand paper. On a flat piece I will use a random orbit sander but had to do this one by hand as I wanted the frost on the inside of the lens. The acrylic pipe came from Outwater Plastic Outwater Plastics Industires. Not finding any that I liked in a ready made is what drove me to make this one. I will make more for sure but will set up jigs to make the cutting of the backer block easy. Also wanted to maximize the light output so the lens was a critical part of the project. Almost left the lens clear but my bride didn't like that.
HowieE
No problem to take the lens off. Attached is a shot of the arrangement with the lens off. Thanks for the LED design site. I purchased the LED strips already made up with resistors in place, from http://www.superbrightleds.com/ Later tonight I will photo the fixture in place with the lights on. I should have also taken a photo of the lens off. Oh well, likely won't do that now. :-)
AIR# 3913
Old 04-02-2008, 05:45 PM   #8
vswingfield
vswingfield's Avatar
Profile:  1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Rivet Excellent!
Very nice work, Royce!
Innovative and elegant. I like the Maple base and the lens solution is brilliant! Rim shot please.
I have found that I am unable to tolerate cool whites in either LED or fluorescents. I am very happy with the light I get from the Phillips Warm White fluorescent tubes I get for my Thinlites at Home Depot, but it does seem that they don’t last all that long in a Thinlite. It also seems like Thinlite ballasts are problematical, too. Besides, LED have way more cool factor. I may have to make an initial purchase of a few of each kind and evaluate for myself. Then maybe I’ll make myself some local knockoff of Royce designer lights.
For my curiosity, which 2 are the warm whites?
Vaughan
vswingfield is online now   Reply With Quote
Old 04-02-2008, 06:09 PM   #9
Royce
Royce's Avatar
Thank you vswingfield. There is no way to tell when they are off as near as I can see, keep the packges identified. Only when turned on then it is apparent. BTW, I noticed after install that I somehow got three of the warm strips in place not two. That will be apparent when I am able to photo with the light on later this evening after dark. I see I forgot to list the LED info. They are the LB3-cool or LB3-warm
AIR# 3913
Old 04-02-2008, 06:15 PM   #10
vswingfield
1967 24' Tradewind
I’m glad that I’m not the only one to do things like that. I guess it is still light there. It’s dusk here in Little Rock, and it is cloudy and dark. If it was clear, it would still be pretty bright.
Complements again on the nice work.
Vaughan
Old 04-02-2008, 08:08 PM   #11
Royce
Royce's Avatar
Here are a couple of shots of the lamp installed. One flash off next with flash on. Please ignore the funky yellow color of the wall paper. One of the previous owners viciously attacked the interior with a paint brush. We were able to get the paint off but it left a stain, so we will have to paint the vinyl Repainting to a light off white will be the next project.
I would say that the 8 strips of 6 LED's each are about as bright visually as the original fixture with 3 automotive lamps. I am not a lighting engineer so YMMV.
ID:	57503  Click image for larger version
AIR# 3913
Old 04-02-2008, 08:46 PM   #12
Royce
Royce's Avatar
I finally woke up enough to remember that I have a fine Zone VI modified one degree spot light meter. So back out to the Minuet. Reading reflected off the palm of hand 18” from the fixture. New fixture reading is 8, and the fixture in the Bathroom which is the same fixture as the one removed from the galley and the reading is 7.66. So they are very similar, at least in terms of what B&W film would see.
AIR# 3913
Old 04-03-2008, 07:07 PM   #13
vswingfield
1967 24' Tradewind
Thanks for the photos. Ok, you are one of the few people I know who have a spot meter.
Vaughan
Old 04-07-2008, 06:16 AM   #14
Royce
Royce's Avatar
A question was asked regarding the power usage. Here is what I am able to observe with limited test equipment. With volt meter attached, the old fixture would drop the battery voltage 0.5 volts and it would not recover completely when you turned off the light, the new fixture drops the voltage 0.01 volts and it recovers instantly when you turn off the light. How much better? I am sure there are better ways to measuer power consumption but this is something to go on.
Oh, as as to the spot meter. I have no excuse other than it helps in low light conditions and saves on bracketing with that pricy 4X5 film.
AIR# 3913
05 safari LED brake light.. safari25-05 Lights - Interior & Exterior 2 11-06-2007 08:38 PM
LED tail light conversion Pahaska Electrical - Systems, Generators, Batteries & Solar 137 05-08-2007 01:06 AM
Scare light and marker light won't work??? shinybean Lights - Interior & Exterior 12 02-12-2007 08:51 PM
LED Tail Light Problem wdkueser Lights - Interior & Exterior 7 09-16-2006 06:58 PM
4-Inch 10-LED stop turn tail light ($11) COUPON** Wabbiteer Electrical - Systems, Generators, Batteries & Solar 1 07-20-2006 09:27 AM
