Old 10-08-2007, 09:43 PM   #1
1979 31' Excella 500
Detroit Area , Michigan
Images: 43
Melted exterior floodlight cover
I seem to have melted my plastic floodlight cover on my 1979 31' International. Does anyone know where I could buy a new one, maybe even a glass one?
wacnstac is offline   Reply With Quote
Old 10-08-2007, 09:46 PM   #2
1984 31' Excella
Norfolk , Virginia
Images: 11
Melted Light
Yea, I had to replace mine too.
Tomorrow I'll get you a phone number.
They are a standard semi-tractor trailer back up lens.
Beginner
Beginner is offline   Reply With Quote
Old 10-09-2007, 11:45 AM   #3
To prevent this recurring, the usual advice is to replace the bulb with a 1141 type:
http://www.airforums.com/forums/f160...ght-10432.html
Of course, you might already have one fitted............
Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 10-09-2007, 11:54 AM   #4
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Is this what you need?
4" Round Lens - Porch Light
Shari
Old 10-09-2007, 11:54 AM   #5
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
I went to a You-pull-it style automotive salvage yard (junk yard) with a friend for a part for his old Chevy truck. There was a bunch of old large trucks there - I got 4 lenses - 3 clear and 1 amber for $5. Not new but fully functional. My old Caravel has 2 scare lights and these are for her. Just a thought in case you want to do the same.
Mike
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 10-09-2007, 02:21 PM   #6
Images: 43
Shari
That looks like the one.
Old 10-09-2007, 04:07 PM   #7
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
I noticed when I was out by ours that ours has melted also and we never use it. I guess it just really got hot this summer!
Family of Disney Fanatics
WBCCI# 4821
Old 03-24-2008, 07:05 PM   #8
1969 29' Ambassador
orange Park , Florida
These lenses can be purchased through NAPA also. I purchased 3 for my 69 as they are the same as the BU lights. Part # 99176C. Instead of having signal stat on them they have TruckLite on them.
69AmbassFl is offline   Reply With Quote
Old 03-24-2008, 09:28 PM   #9
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I replaced my entire fixture with one from Vintage Trailer Supply as noted in a previous post. I rarely use this scare light but when I converted over to a 36 bulb LED board, I pulled out an 1156 bulb. No wonder these plastic lenses warp or melt.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 03-24-2008, 09:40 PM   #10
LLB21's Avatar
Try a frosted bulb? Then the lens won't melt.....maybe.
Louie
LLB21 is offline   Reply With Quote
Old 03-25-2008, 05:40 AM   #11
1984 31' Excella
Norfolk , Virginia
Images: 11
Outside Flood Light
You are using the wrong light bulb. Mine melted also, I dont remember what the number is but it is not an 1156. I see if I can round up the number or as Andy of Inland RV.
Beginner
Old 03-25-2008, 08:42 AM   #12
1969 29' Ambassador
In my 69 it says use a 1034 for the flood light. This bulb will not work in mine.This bulb has 2 contacts and the lock tabs are not even accross. It has a 32 candle power rating, as does a 1156. The 1141 bulbs that are used on the interior light fixtures has a rating of 21 candle power, it is what I have in mine and is pretty bright. You can use frosted or not in the 1141 style.
Old 03-25-2008, 08:45 AM   #13
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
You need to use the lower wattage bulb in both instances. The earlier trailers used double filament bulbs, the newer ones single. The higher-watt bulbs will soften and distort the plastic lens from the increased heat.
Old 03-25-2008, 10:53 PM   #14
davidz71's Avatar
1986 25' Sovereign
You might also consider a #93 bulb which uses less current than the 1141 bulb. It is 1.04 amps vs. 1.44 for the 1141.
#93 bayonnet bulb - Google Product Search
Craig
AIR #0078
3.73 rear end
Custom Cover to protect exterior or not? goldenlily Winterizing, Storage, Carports & Covers 1 09-30-2005 12:17 AM
Exterior electrical outlet cover airstream4 Exterior Restoration Forum 1 12-05-2004 02:37 PM
Help!! exterior outlet cover stuck TheBigRedTruck Electrical - Systems, Generators, Batteries & Solar 8 06-28-2002 12:04 PM
Exterior 120 volt outlet cover thenewkid64 Electrical - Systems, Generators, Batteries & Solar 8 06-16-2002 09:54 AM
