Old 05-24-2007, 02:40 AM   #1
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
Marker Light Gasket - where
Hi,
I am looking for the Marker light gasket.
Vintage AS supply carry the light but I didn't find the gasket for it.
Any info
thanks
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Old 05-24-2007, 05:01 AM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Originally Posted by dufferin
Hi,
Any info
thanks
Which trailer are you working on? If it's one of the '70s coaches in your profile, you can get complete clearance light assemblies from LED-R-US that look exactly like the ones on your trailer. They are about $6 each, and they will last probably as long as you own your coach. If you don't want LED lights, I got a set for our '72 from Wal-mart for about $2 each.
Old 05-24-2007, 05:14 AM   #3
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
it's for my 75, as I will soon (I hope) polish it I want to replace all the gasket, but if it comes all in one it won't hurt.
BTW thanks for the Wall Mart tip.
TAC# : QC-1
my blog
Old 05-24-2007, 07:47 AM   #4
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
If it's like mine, there no longer is a gasket. You cover the hole in the skin with waterproof aluminum tape, poking the wire through the tape. Right before you attach the light, you dab on a dollop of Vulkem or Trempro or caulk of your choice over the hole in the tape, and attach the light and you're done.
John
Visit my Camping Blog!
AYRSTRM2 is offline   Reply With Quote
Old 05-24-2007, 09:28 AM   #5
1953 Flying Cloud
1953 Flying's Avatar
1953 21' Flying Cloud
West Sacramento , California
Images: 8
I went to the local auto parts store and baught some cork sheets that is used to redo the mantifolds on engines. This seemed to keep it water tight after you re-enstall the screws or in my case rivetts. I hope this helps.
1953 Flying is offline   Reply With Quote
Old 05-24-2007, 09:30 AM   #6
Airstream 65's Avatar
1965 26' Overlander
2009 27' FB International
Winnipeg , Manitoba
I'm going to be replacing all my marker lights soon, how is the light attached to the trailer? (1965 Overlander)
Airstream 65 is offline   Reply With Quote
Old 05-24-2007, 12:50 PM   #7
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
thank to you.
AS65 mine are attached with rivets. Remove the caps and you'll see it. It could be screw from what I eared.
TAC# : QC-1
my blog
Old 05-24-2007, 12:59 PM   #8
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
If you buy them direct from Airstream they come with gaskets. I've not installed them yet but looked at them at local dealers and Airstream (on this item) was no more expensive. Believe they were like $4.00 each.
Old 05-24-2007, 03:42 PM   #9
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Never thought to check AS... thanks
TAC# : QC-1
my blog
Old 05-24-2007, 04:15 PM   #10
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Some auto & marine suppliers carry neoprene sheetinng in various thickness's starting at 1/16"
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Outlet under sink, night light LI Pets Electrical - Systems, Generators, Batteries & Solar 5 09-24-2006 05:25 PM
marker lights dont work wb13798 Mechanics Corner - Engines, Transmission & More... 6 11-09-2002 11:40 AM
marker lights bhsl8 Lights - Interior & Exterior 6 09-12-2002 06:01 AM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 03:37 AM
Clearance light wiring Bob Evans Lights - Interior & Exterior 6 05-27-2002 11:03 AM
