Old 10-06-2011, 09:10 PM   #43
Splitrock's Avatar
Sioux Falls , South Dakota
@-----> Barry
Maybe you have 5 separate and independent electrical failures, affecting all three electrical systems at once, all coincidental, and all unrelated. I rather doubt it, but I guess it's possible.
With my trailer, I found every wire is testable with either a multi-meter, a small battery charger, a test light, or all three.
My towing 12 volt light system is separate and not related to the converter/battery coach 12 volt power system. The converter is a very straightforward piece of equipment and very easy to test. The battery is like every other battery and is easy to test. The 120 volt system is very simple and easy to test.
For 120 volt quick and easy, I like the no contact voltage testers. I've had open grounds on 120 volt that tested hot but didn't work to power anything except the tester. I think it would have powered me if I had done a bathtub test on it.
As far as identifying the broken damaged wire, that's going to be pretty easy to identify by eliminating everything that's working. All the wires on my trailer have a start and an end. When I find one that has a start and no end . . . I bet that's the one that's broken:-)
Old 10-06-2011, 09:25 PM   #44
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
Ah... and so we have come to the final conclussion... the answer being you know what you are doing and I am a total novice when it comes to electrical issues... In fact you may have a hard time believing this but I'm not sure what you even said. What's a no contact voltage tester and how would I begin to you it to trace curcuits and find where the problem(s) are? Where do you recommend I begin?
Then again I don't suppose you know much about artifical insemination of raptors or the proper way to imprinbt a NA goshawk.
goshawks00 is offline   Reply With Quote
Old 10-06-2011, 09:30 PM   #45
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
One thing you can do to try to isolate;
With Univolt plugged in and battery connected you said everything works.
I would start by removing the wires off the out put of the "12VDC" breakers one at a time to see what each breaker powers.
Garry
Old 10-06-2011, 10:02 PM   #46
Splitrock's Avatar
Just go to any home center and ask for a no contact voltage tester. Cost about $10. I'd start at the 120 volt source outlet, the 120 volt breaker panel, the converter, and the umbilical trailer connection. And I'd be dreaming about removing that inside panel where the original wire was damaged.
I would have a problem there, no doubt. Hahaha!
Old 10-06-2011, 10:03 PM   #47
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
Yeh, it is pretty overwhelming at first, but eventually you get it, or some of it. One good thing about electricity is that it is very logical and by process of elimination, a pretty standard troubleshooting strategy, things get figured out. And, it can only get better, eventually.
I suggest tagging each wire with some tape or paper and tape when you figure out what it does. Then you don't forget what it is. You can make your own diagram of the system. By organizing thusly, you may better understand what you are doing.
One of the standard easy manuals for residential wiring is available lots of places—I've even seen it in Lowe's—is Richter's Wiring Simplified. It can introduce you to the basics of residential wiring and may make it easier to understand 12 v as well. The principles are the same. It takes time to get it. As far as I'm concerned plumbing is a lot harder and I wouldn't where to start with a raptor.
Gene
Old 10-06-2011, 10:08 PM   #48
richinny's Avatar
2011 34' Classic
barry, in simple terms you just have to follow the power line.
with the negative lead of the tester or light, start from the battery positive cable and keep testing the route of the wire. the first line goes to the + buss bar. i believe you got a voltage reading there. the power should be hot in and out of each fuse or breaker. the battery line should connect somewhere with the converter. if the converter is not putting out a charge, you might be reading battery voltage at the converter output.
after unplugging the 120v line to the trailer and disconnecting the battery, you can try disconnecting the converter line from the fuse panel (do not let any wires short anywhere) , repower the 120v line and see if there still is voltage out of the converter.
Ricky
Old 10-07-2011, 07:40 AM   #49
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Ricky
After doing this I get 4.0v at the converter with converter plugged in, bat. disconnected
Splitrock ( funny name!) I will pick up a no contact tester today... and will be asking you how to trouble shoot with this.
Garry I will 'plot' these circuits today , as best as I can.
Thanks all, I like the analytical approach.
Barry
Old 10-07-2011, 09:10 AM   #50
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
here is a drawing of current wiring:
Old 10-07-2011, 10:08 AM   #51
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Breaker #1 controls:
2 front gaucho lights
front overhead light
sink light
stove exh. fan
furnace fan and thermostat
(all these don't work unless the sore line is hooked w/power coming from the Univolt)
Breaker #2 controls:
roof vent
magic fan
bathroom light
Breaker #3 controls:
porch light
2 rear gaucho lights
front window light
water pump
(all these work whether 12v or with Univolt attached)
Barry
Old 10-07-2011, 04:56 PM   #52
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Looks like all you need to do is put a jumper between fuse 1 and fuse 3. Put the jumper on the top side of the fuses in your drawing. Everything should work after installing the jumper whether you are on shore power or battery.
Old 10-07-2011, 06:20 PM   #53
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Guys I got to tell you..It really is a testament to this site and the type of folks that will spend the time to help a fellow 'streamer out, even a 2 monther like me.
Garry from OK. spent several hours today on the phone and exchanging emails helping me get the thing done...
After much deliberation and experimentation,checking out wjhat worked on more like what didn't work, he walked me through installing the PD9245. BTW you guys that did it in forty five minutes, I tip my hat to you... It took me that long just to run an AC box to plug the PD into, and close to 2 1/2 hours to finish the job..
Drum roll!!!!!!!!!!!!!!!!!!!! It's alive. Everything works both DC and AC. Thank you Garry you are a borderline genius!!
Barry
Oh!! anyone want a no contact tester...cheap!! Never used it though it is cool to play with to see how it worked..
Old 10-07-2011, 06:39 PM   #54
Master of Universe
Gene's Avatar
Keep the tester. You'll need it sometime.
Gene
Old 10-07-2011, 07:11 PM   #55
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Thanks Gene, though I hate your optimisim!
Old 10-09-2011, 12:15 PM   #56
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Yeah! Glad you're up and running! So besides a dead univolt, what else did you find out?
Screw on Porch Light 1964 robwok 1960 - 1964 Overlander 17 06-06-2014 10:24 PM
Fix for Dinette Table Wobble Road Geezer Cabinets, Counter Tops & Furnishings 9 07-13-2012 07:38 PM
Where can I screw (things) up? johnfreeman6 Member Introductions 8 06-26-2011 07:49 PM
Screw length for side of refrigerator AirHome Refrigerators 2 06-04-2011 08:39 PM
Can't stomach screw holes in new Airstream interior... dekew Upholstery, Blinds, Walls & Interior Finishes 24 01-07-2011 09:34 AM
