Old 10-01-2014, 09:06 AM   #1
1986 25' Sovereign
Houston , Texas
Lost Power
I just purchased an 86 soverign and put in a 30 amp breaker at my place to hook it up to. On the first try I think I wired the breaker wrong and blew everything. The TV fried. I rewired the breaker and now the A/C and outlets work but not the refigerator or interior lights. Is there something I can do or did I fry them as well? At first the lights came on dim and the alarm for low battery sounded. Any thoughts greatly appreciated.
Silver Miner is offline   Reply With Quote
Old 10-01-2014, 09:09 AM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
If you wired the 30 AMP like a household type...you wired it wrong and gave the Airstream a 220v shock. You fried almost everything. RV 30 AMP IS NOT the same thing and many folks have learned the hard way. I came close once.
Old 10-01-2014, 09:12 AM   #3
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
If you originally wired the outlet for 220 instead of 110 volts, then you may have fried almost everything. Sorry.
It's a mistake that has even happened to professional electricians. Lots of people think all funny-looking receptacles are 220.
110 requires a different circuit breaker, back at the panel.
There is no 220 volt equipment in your trailer. It's all 110.
Old 10-01-2014, 09:16 AM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
The above is correct. 30 amp RV power is only a 30 amp breaker on 120 volt line.
The frig and interior lights a 12 volts DC. You may have fried your convertor and killed the batteries. Disconnect the batteries at the convertor output and try charging the batteries an then try the lights.
2004 Excursion 4x4
Lost power to the keyless entry system 92landyacht Land Yacht/Legacy Motorhomes 9 02-06-2013 05:59 PM
Removed control panel and lost all power? deerhunter Electrical - Systems, Generators, Batteries & Solar 1 05-13-2012 10:40 PM
Lost all 12V power Flynavy Electrical - Systems, Generators, Batteries & Solar 22 06-29-2011 05:49 AM
Lost partial power- please help. argo76 Argosy Motorhomes 5 11-17-2009 02:05 PM
Lost partial starboard side power Thealt Lights - Interior & Exterior 15 03-21-2009 08:55 AM
