Old 01-24-2013, 06:31 PM   #1
RMB
RMB's Avatar
2010 23' International
Saturna , British Columbia
Question Little External Light
I was connecting my water discharge hose two nights ago and for the first time I saw a small light shining on the connection. Its mounted in the bottom of the trailer just ahead of the discharge coupling.
Whats this??? How do I turn it off? On? No mention of it in the manual.... can anyone help?
Thanks!
International 23/ 2010
"I carry what I can, and leave the rest behind" Epicurus
"All that is mine, I carry with me." Cicero
RMB is offline   Reply With Quote
Old 01-24-2013, 07:07 PM   #2
2008 16' Safari
Destrehan , Louisiana
That is your discharge hookup convenience light. There is a small swich near the light to turn it on and off. The switch often fails. It can be replaced with a more durable switch.
dlb435 is offline   Reply With Quote
Old 01-24-2013, 07:12 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
The switch s a bit hard to see...it's a push-button switch under a rubber covering.
TB & Greg and Abbey Schnauzer
#3954
Old 01-24-2013, 08:16 PM   #4
RMB
RMB's Avatar
Super ! Thanks to both of you.
I got down under the trailer and indeed found the light switch - or I should say, found the hole where the light switch is supposed to go. I think the outside securing nut must have fallen off and the switch is now inside the body molding. That will be a job for tomorrow in the light.
I hope that plastic panel comes off easily.....
Old 01-24-2013, 08:37 PM   #5
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
Hey DLB435, where is a good place to get a replacement switch? Mine sometimes works.
Old 01-25-2013, 12:06 PM   #6
2008 16' Safari
I cheated just a little bit. I have about a half a hardware store out in my shed. I just rumaged around until I found this:
they sell for about $30.00
