Old 10-05-2010, 07:44 PM   #1
1978 29' Ambassador
me , Texas
Lights not working, inside and out - '78 Ambassador
In my kitchen, overhead light is not working along with the lights over the sink, the exterior step and flood lights and one of the reading lights over the front couch ('78 Amabssador 29'),
Does this sound like a related problem, any suggestions?
qratio@gmail.com
qratio is offline   Reply With Quote
Old 10-05-2010, 08:19 PM   #2
Ottawa , ON
Hi there!
Did you do the obvious, like check the fuse panel (the 12V one, on that thing in the back that hums)?
Old 10-05-2010, 09:37 PM   #3
x
XXXX , XXXX
All those lights are on the same circuit. Like AAGE suggests check the fuse panel for blown fuses. The glass type fuse holders can get loose as well or the fuse itself can be damaged and look fine. Use a multimeter to make sure you have power on both sides of the fuse. If you have power there and still no lights then you have a break in the wire somewhere between the panel and the first light on the circuit which will be the overhead light in the kitchen. Check for power at every light in the circuit until you find where the break is. If you replace the fuse and it immediately blows again you have a dead short somewhere in the circuit. Again start at the beginning of the circuit and check for contiuity to ground until you find the short.
wasagachris is offline   Reply With Quote
Bathroom lights not working BCMC27 Lights - Interior & Exterior 5 06-29-2013 08:10 PM
water tank in '62 Ambassador/are tanks coated inside? SANTINO MARC Fresh Water Systems 1 01-19-2010 09:32 AM
75 Argosy 24 Inside Lights rusty47 Batteries, Univolts, Converters & Inverters 2 07-31-2008 01:20 PM
no 12 volt lights working marifn Lights - Interior & Exterior 9 12-12-2007 06:40 PM
Working on the inside...woodworking...& refinishing Dureedesign Upholstery, Blinds, Walls & Interior Finishes 12 06-09-2007 03:31 PM
