Old 06-06-2016, 09:18 AM   #1
1972 29' Ambassador
Saint Charles , Missouri
Lights not functioning 1972 Ambassador
New member here!
Just purchased an original 29' 1972 Airstream Ambassador (all original). The PO doesn't recall what exactly happened but none of the interior lights currently function. Upon hooking up to power to the campsite, ALL of the interior outlets work fine as well as the AC.
I checked and the battery is MISSING, so i'm wondering if a battery is hooked up, will that complete a circuit of some sort to make the lights work or sound like there is a short or wire disconnected somewhere?
PS: The fuses all appear fine.
No lights function anywhere inside - any thoughts?
Thanks for any suggestions!
Cloud9Air is offline   Reply With Quote
Old 06-06-2016, 05:59 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
You need a source of 12 volt electric power to run your interior lights. The uni - volt converts the 120 volt power at the campsite to 12 volts.
If you have a battery, that would also be a source of 12 volt power for u our lights.
Old 06-06-2016, 06:34 PM   #3
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Hi, and welcome to Air Forums. You picked a good spot to get some ideas on how to solve your 12v problem.
You didn't mention if any of your 12v appliances work. Vent fan, water pump, furnace fan and the like. If not, then your converter is not supplying 12v to the trailer's 12v circuits.
The 115v AC shore power does have a circuit that powers the converter. My 66 and the son's 69 have a dedicated circuit with circuit breaker in the breaker box running to the converter. You need to verify you are supplying 115vAC to the converter.
Some converters have an internal fuse to protect them from overload. Sometimes this fuse is inside the case of the converter. If this fuse is blown, then the converter is not supplying 12 volts.
So grab your multi-meter and start testing. Good luck. You'll find the cause.
David
Old 06-06-2016, 08:59 PM   #4
drboyd's Avatar
1978 25' Tradewind
I've got $5 paypal right now that says no other 12v appliances or stuff works. It can't.
Old 06-06-2016, 09:16 PM   #5
1991 25' Excella
Stanfield , Oregon
Put a new battery in before you go any further.
SpletKay06 is offline   Reply With Quote
Old 06-06-2016, 10:12 PM   #6
1971 31' Sovereign
Indian Wells , California
You don't need a battery for your 12V to work. I say the Univolt is bad. Same thing happened to my '71.
CraigCA is offline   Reply With Quote
Old 06-06-2016, 10:16 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Does a converter even exist? If it is an old Univolt you may want to upgrade to a modern multistage converter prior to purchasing a battery. You will need the converter to keep the battery charged.
Old 06-07-2016, 09:36 AM   #8
1972 29' Ambassador
Re:
Thanks to all - im picking up a battery tonight and will try that first (cheapest route). No vent fans work, etc like someone suggested so im hoping this is a quick easy fix. The camper was always used in a campground to plug into so i think the PO just used lamps inside and never bothered with a battery replacement.
Just wanted to touch base here first with the experts first, will install it on thurs and keep u posted. Thanks again people!
Old 06-07-2016, 09:58 AM   #9
1971 31' Sovereign
Palm Desert , California
Be careful because of bad Univolt can fry your battery.
CaCraig is offline   Reply With Quote
Old 06-07-2016, 10:44 AM   #10
drboyd's Avatar
1978 25' Tradewind
A bad univolt and a good univolt have that in common - both will shorten your battery's life. You'll want to look into a new solid state voltage converter, as cooler, quieter, lighter and much better for your battery.
A lot of us have had good luck with Progressive Dynamics converters from bestconverter.com.
Old 06-07-2016, 11:37 AM   #11
1973 25' Tradewind
Redding , California
I am going through this right now in my '73 Trade Wind. Shore power the outlets worked, But not the 12v system. I bought a battery and the 12v worked, for a day, then the battery died. The univolt wasn't charging the battery. My new converter and 12v panel should arrive tomorrow. Make sure to keep the receipt on the battery, in case the univolt fries it, like it did mine. You learn a lot about a lot of things owning an old airstream.
Leadvox is offline   Reply With Quote
Old 06-07-2016, 12:10 PM   #12
drboyd's Avatar
1978 25' Tradewind
Originally Posted by Leadvox View Post
<snip> You learn a lot about a lot of things owning an old airstream.
Yeah! Whether you want to or not!!
Old 06-07-2016, 01:18 PM   #13
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Univolts are NOTORIOUS for boiling batteries. Also, it is rumored that using a univolt without a battery in the system, as a 12v power supply, will cause its untimely demise. It sounds like this may have already happened. Whether or not, your best bet is to order your converter right away as well, and don't risk damaging your new battery.
Old 06-07-2016, 05:53 PM   #14
1972 29' Ambassador
Good heads up, thank you.
Keep me posted on exact converter you buy, i will return my battery back to Menards on Monday if that happens to me. They take anything back
Newbie Needs Help - 86 345 MoHo Fuel Gauge Not Functioning Properly gizzyguy Mechanics Corner - Engines, Transmission & More... 3 09-17-2015 02:01 PM
Brake lights, brake controller not functioning adwriter73 Brakes & Brake Controllers 17 01-16-2014 09:37 AM
Functioning Normally? holtenc Electrical - Systems, Generators, Batteries & Solar 14 11-05-2013 08:16 AM
1972 Airstream International Land Yacht Ambassador :: 1972 Airstream Ambassador airpatton Airstream Registry Discussions 0 03-22-2012 12:01 PM
110 outlets not functioning mguinn Electrical - Systems, Generators, Batteries & Solar 5 07-09-2010 07:21 AM
