Old 07-29-2010, 04:39 PM   #1
will sch
maurepas , Louisiana
Unhappy lights keep tripping
i have 3 overhead lights anyone will light ok and stay on but if i put 2 are 3 on at the same time they will trip and restet and trip over an over help all grounds are clean ????
will&bonnie is offline   Reply With Quote
Old 07-29-2010, 05:39 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you are tripping a circuit breaker the breaker may be week and need replacing. Look at the circuit breaker and see what rating it is and as a quick test put a fuse o that rating in place of the breaker. If the fuse blows you have an overload most likely from a short in one of the second or third lights.
If the fuse holds replace the breaker.
2004 Excursion 4x4
No running lights or tail lights... goswick Lights - Interior & Exterior 24 02-27-2010 09:31 AM
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 08:46 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 06:43 PM
