Old 07-13-2011, 10:15 AM   #1
1971 31' Sovereign
fresno , California
lights for AS
I have a Ford F 150 xlt with the tow pkg and was wondering about the compatability of the Airstream plug with my newer truck. Is there an adapter available or do I need to ad a new plug.
imbighoe is offline   Reply With Quote
Old 07-13-2011, 11:00 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Ah, in the other thread I don't think you specified "with tow pkg."
The F150 tow package should have a 7-pin "blade" socket to the left of the receiver. Its pin-out is the modern standard 7-pin layout, and should work fine for you. *IF* the Airstream has never been connected to a modern vehicle, it may still have a non-standard pinout that you may need to adjust.
Here is a link to the standard pinout. Note the "notch" in the trailer plug and the tab in the socket are the way to locate which pin is #1, and that #7 on the diagram is the center pin. If your trailer's connector is molded together and you can't swap the wires (and they're not already in the modern layout to match your truck) you can use an adapter or change the truck's layout, but changing the truck should be your last option since any modern trailer should use the layout your truck already has.
David
Electrical issues with clearance lights 1987_345 Classic Motorhomes 13 08-25-2011 08:13 AM
LED interior lights: A complaint hampstead38 Lights - Interior & Exterior 0 03-23-2011 08:38 AM
Minus these lights SilverHoot Lights - Interior & Exterior 20 02-13-2011 09:04 AM
Moving from center lights to multiple puck lights mikeandnora Lights - Interior & Exterior 10 02-11-2011 09:47 AM
Bedroom lights won't work! julieibach Lights - Interior & Exterior 1 01-24-2011 10:14 PM
