Old 01-24-2012, 06:19 AM   #1
chrischarles's Avatar
1977 31' Sovereign
Florence , South Carolina
Lights
Does anyone know where to get a replacement lens for these lights? The lights are for our turn signals.
ID:	149480   Click image for larger version
chrischarles is offline   Reply With Quote
Old 01-24-2012, 06:42 AM   #2
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
Try Vintage Trailer Supply or Inland RV.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 01-24-2012, 08:13 AM   #3
1974 Argosy 20
Kooskia , Idaho
The first photo is probably the polarity indicator light which itself is more dangerous than useful (no wars now, the subject has been covered in other threads). Personally, I would not bother replacing it unless you are doing a museum restoration.
The second photo is of the display end of the fiber optic tail/stop light indicators. There are no bulbs under the little plastic display ends, only the fiber optic line which runs to the tail/stop light itself. Although I certainly am not sure what all is out there, this was an Airstream designed system, and most likely AS part. I kinda doubt they are available but Inland RV would be my choice for looking.
Old 01-24-2012, 08:18 AM   #4
x
XXXX , XXXX
I think you are slightly mistaken. The first picture shows the polarity lamp. It is connected to the 110VAC system and will not illuminate unless the polarity of the 110VAC system is reversed.
The second picture shows the taillight monitor system. they are not lights but are fiber optic cables connected to the taillights. When the brakes are applied or the turn signals are activated or the running lamps are on these fiber optic cables will transfer the light down the cable and you will be able to see this in the outside rearview mirror of your tow vehicle.
I have never seen the polarity light available anywhere and for the taillight monitor I have only seen the cover available from Inland RV.
try calling Andy at Inland RV as he carries many more parts that he shows on his website.
Inland RV Center - The Nations Leading Expert in Airstream Innovations
wasagachris is offline   Reply With Quote
Electrical issues with clearance lights 1987_345 Classic Motorhomes 13 08-25-2011 08:13 AM
LED interior lights: A complaint hampstead38 Lights - Interior & Exterior 0 03-23-2011 08:38 AM
Minus these lights SilverHoot Lights - Interior & Exterior 20 02-13-2011 09:04 AM
Moving from center lights to multiple puck lights mikeandnora Lights - Interior & Exterior 10 02-11-2011 09:47 AM
Bedroom lights won't work! julieibach Lights - Interior & Exterior 1 01-24-2011 10:14 PM
