Old 08-22-2011, 09:04 AM   #1
jump's Avatar
2013 30' International
lubbock , Texas
Lighting '82 excella
So, I needed to replace the door deadbolt ... I removed the panel with the three light switches and then replaced the deadbolt ... replaced the panel and THOUGHT I had repaced the wires correctly but now the lights (controlled by these 3 switches) don't work. Does anyone have a wiring diagram that can show how the switches are supposed to wire up?
Name:	Airstream Switches.jpg
jump is offline   Reply With Quote
Old 08-29-2011, 11:54 PM   #2
Dan@LED4RV's Avatar
Denton , North Carolina
easy stuff first.
I'm sure you have checked the fuses. You can't just look at them. You need to test them with a meter or a test light. If the fuse is good I would take the switches off and get a jumper wire. Whatever the ground color is, that color will be present at all 3 switches. It is either white or black. Just keep playing with it until you figure it out.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
What makes an Excella an Excella? MaraLindstro 1990 - 1993 Excella 16 07-08-2012 11:05 PM
Should I buy a 1979 Excella 24'? (Boy do I want to!!) PuffinPotter General Motorhome Topics 2 07-17-2011 01:47 PM
Excella Info? M Williams 1981 - 1983 Excella 4 01-26-2011 07:13 PM
