Light/vent question '78 Ambassador
The switch that controls lights appears to have a short. Red wire attachs to connector (whatever that flat piece of metal is called) and the connector appears to be loose. The other two are tight. They are riveted to switch. The switch works, but can see electricity spark and lights dim when you wiggle the red wire. Is this something I can fix or do I need to replace? Found the replacement at ODM.
The handle to raise the vent cover is stuck and won't turn with light pressure. Do not want to force it. Where to spray WD40?
Thanks. Jack
