Old 07-14-2011, 04:50 PM   #1
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Light switch question
I see all kinds of 12V switches for sale. They are usually toggle/ or rocker type. Will a regular household 110V light switch work for 12V switching?
SilverHoot is offline   Reply With Quote
Old 07-14-2011, 05:18 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Yes
Chris
Old 07-14-2011, 05:27 PM   #3
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
Some of the 50's and early 60's trailer used them in the 12 volt systems and i have used them in some added circuits
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 07-14-2011, 06:00 PM   #4
SilverHoot's Avatar
1967 24' Tradewind
Thanks Chris and Rick. I thought so. There was a switch on the ceiling as you entered my 67 that I think probably was for 12V lights. Since I tore it apart prior to checking I thought it best to be sure. Bet it is a bad idea vice-versa though.
Old 07-14-2011, 08:04 PM   #5
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
That household-looking switch runs the light over the galley area. It's double-switched, so for the switch above the door to work, the switch at the light itself has to be on, too. It's mighty handy if you wind up coming back to the rig in the dark.
Lynn
WBCCI 21043
Old 07-15-2011, 06:29 AM   #6
SilverHoot's Avatar
1967 24' Tradewind
Too late
Lynn
Thanks for the info!
Too late now, mine is now wired to turn on the ceiling lights...when I get them
Old 07-15-2011, 07:23 AM   #7
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
The switch in my 61 located in the ceiling slightly to the right of the door is for the main ceiling 120 volt lite.
Possibly by 67 they had gone to all 12 volt lights.
13 Ram 2500 TD
Old 07-15-2011, 07:39 AM   #8
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Yep, you're right. There are no high-voltage lights in the 67. The only things run by the 110v. system are the converter, the AC, the 110v. outlets, and the fridge (if switched to that setting).
Lynn
WBCCI 21043
Old 07-15-2011, 07:51 AM   #9
Central , Mississippi
I spent a few years designing switches and can confirm the 110v switches, although they will usually work, will fail sooner than they are supposed to when used on 12v...be prepared to only get, say 5,000 cycles instread of, say, 10,000
My '63 has the same switches for 12V as the 110V lighting...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 07-15-2011, 08:13 AM   #10
Minno's Avatar
1972 31' Sovereign
If you mean using a 12 volt switch for a 110 VAC circuit, it depends on the switch. In general, you're right. But there are some switches out there sold as 12 VDC switches, that if you read the specs, are rated to switch 110 VAC circuits as well.
Chris
Old 07-15-2011, 08:44 AM   #11
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
I hate it when a switch fails after only 5000 cycles
13 Ram 2500 TD
Overhead Light Switch "HI-LIGHT-LO" motilley Lights - Interior & Exterior 14 08-23-2017 06:11 AM
Interior Light Question gaylejoe Lights - Interior & Exterior 3 05-21-2011 10:15 PM
Master switch / Storage question polarlyse Winterizing, Storage, Carports & Covers 1 05-16-2011 05:26 PM
Master Switch question polarlyse Electrical - Systems, Generators, Batteries & Solar 0 05-13-2011 08:17 AM
2006 Safari Interior light switch Goal15 Lights - Interior & Exterior 7 05-03-2011 01:36 PM
