Old 10-04-2008, 04:40 PM   #1
The Flintstones's Avatar
1970 27' Overlander
Houston , Texas
Light Socket Source
Hi All
All six lights on the two horizontal light fixtures on the rear wall in the twin bed area are shorting out from wire being exposed and dry rotted. I would like to replace sockets with new ones but I am unable to find a source for such a simple common (I thought) light? Auto parts stores and Home Depot and a local rv store have been a bust. I can find a whole new light but don't want to replace. Just want a new socket to rewire in and re attach. Already tried to fix existing but they are in bad shape. Any help is appreciated. The bulb is the single pole with the two slots that you push in and twist. I am unable to find on internet either. . .
thanks
James
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 10-04-2008, 07:16 PM   #2
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
This is all I have been able to find so far, short of cannibalizing a cheap taillight.
They might have what you need.
Automotive Light Bulb Sockets
If you want to only replace the pigtail, those are definitely available.
http://www.taillightking.com/images/...et_Pigtail.JPG
Uwe
www.area63productions.com
Old 10-04-2008, 07:41 PM   #3
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I would seriously consider taking a couple of the Thin light fluorescent fixtures apart and upgrade the stock fixtures. Lower current draw, less heat and more light.
Aaron
WBCCI #XXXX AIR #2495
Old 10-04-2008, 09:46 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Aaron
I did that with the lights in our Sovereign, and have been very happy with the results. I've had several Airstreamers look at them after I did the upgrade, and no one could tell they were flourescents. Also, one 15 watt tube uses the same power as a single 1141 bulb.
Source for exterior light, '92 Excella? EA Stein Lights - Interior & Exterior 9 01-29-2006 04:34 PM
Bad swivel light ball & socket Rick T Electrical - Systems, Generators, Batteries & Solar 12 05-15-2005 07:47 PM
Light Bulb Source Found TomW Electrical - Systems, Generators, Batteries & Solar 6 10-27-2004 03:34 AM
Brake light socket needs to be replaced Argoman All Argosy Trailers 5 09-16-2004 12:49 PM
Parts source for four position light switch overlander76 Electrical - Systems, Generators, Batteries & Solar 6 11-16-2003 08:24 PM
