Old 12-23-2015, 02:43 PM   #1
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Light for vintage wet bath
When I got the FC it had a bare 110 volt bulb (with pull chain) mounted to the ceiling in the wet bath - yikes!
I capped the wires and installed a surface mount, battery-powered LED light which ate batteries while failing to provide much light. I have since replaced it with an improved version but still not really satisfied.
I would like to go back to a bright 110 volt light such as this:
Amazon.com: Lithonia Lighting FMML 7 840 WL 7-Inch 4000K LED Small Versi Round Wet Location Flush Mount, White: Home Improvement
The problem is adding a switch that is:
A. Waterproof
B. Rated for 110 volts
C. Has sealed leads rather than posts so that I can mount it in the ceiling space between the inner and outer skins.
Any ideas?
BambiTex is offline   Reply With Quote
Old 12-23-2015, 03:12 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My Bambi II had the same scare light fixture that was used outside.
MICHAEL
Old 12-23-2015, 03:24 PM   #3
cameront120's Avatar
1972 25' Tradewind
Why not get a 12v fixture from any RV supply place? I'm not sure I'd want 110V anything anywhere near a wet bath. The 12V incandescent fixtures in my wet bath are plenty bright enough.
North Vancouver, BC
Old 12-24-2015, 05:47 AM   #4
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Main reason for 110 volt fixture is that my trailer is not set up for 12 volt lighting at present. I have a 110 volt light in my shower at home that appears to be perfectly safe...
Old 12-24-2015, 10:20 AM   #5
1972 25' Tradewind
It should be a sealed unit specifically rated for wet use. I'd also wager that the light switch isn't in the shower enclosure.
North Vancouver, BC
Old 12-29-2015, 10:51 AM   #6
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Agree. I ordered the LED fixture from Amazon along with a waterproof switch. Light is sealed and looks very nice.
Vintage wet bath seal thinktankair Sinks, Showers & Toilets 0 03-30-2014 06:49 AM
How is it to live with a 'wet bath' ? darkStar Our Community 13 09-20-2011 05:17 AM
Has anyone ever converted a regular rear bath to a wet bath? tvadman1963 Sinks, Showers & Toilets 2 12-29-2006 11:15 AM
Wet Bath in 72 Tradewind Lee Pace Sinks, Showers & Toilets 3 11-01-2005 11:14 AM
wet bath - what years? AV8 1970-79 Tradewind 4 01-01-2004 07:16 PM
