Old 05-28-2010, 12:07 PM   #1
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Light Fixture Removal
Anyone know how to remove the halogen hockey puck light fixtures from the ceiling in a newer trailer? I can get the lens off for bulb replacement, and can see the spring on the side of the light can holding the fixture in the inner skin, but can't see how to get it out.
Thanks for any help!
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 05-30-2010, 04:55 AM   #2
Dan@LED4RV's Avatar
Denton , North Carolina
light upgrade
For sure
Dan
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 05-30-2010, 05:58 AM   #3
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
If you want to remove the entire fixture, you have to very carefully pry it out at the outer ring. It's easy to scratch the skin or the fixture. I used a knife blade to pry out. I did this 2 years ago, so my memory is fuzzy, but I believe you have to hold one spring in while then prying out the other side and gently but firmly pulling down until you get both springs out. Those springs can hurt your fingers as well as the aluminum skin.
Gene
Old 04-09-2012, 06:25 PM   #4
scubadog's Avatar
2011 23' Flying Cloud
Flagstaff , Arizona
Originally Posted by Dan@LED4RV View Post
For sure
Dan
Dan,
I wanted to post here how helpful you have been. Thanks again for sending the link to the video on removing the light. It also helped that your website has so many great photos of the fixtures. At first I wasn't at all sure how hard to pull on the light. Those springs have a lot of tension but it helped having some idea of what they look like and how they work. In spite of Katie's warning in the video, I still managed to get a finger in the wrong place. Those springs have a good snap to them.
Instead of removing the bulb or in this case the LED chip, I cut the positive lead, capped it and taped the loose ends to the other wire. That way everything is in place if we decide to hook it up again. Now the bathroom switch turns on ONLY the bathroom light, not the lights over the sink.
Duncan
scubadog is offline   Reply With Quote
Sink Fixture Removal mello mike Plumbing - Systems & Fixtures 1 06-13-2009 12:03 PM
Vintage Light Fixture Light Diffusers flyfshr Lights - Interior & Exterior 5 08-21-2008 06:26 PM
Need some help locating a light fixture bake315 Lights - Interior & Exterior 2 05-19-2008 09:51 PM
60 Pacer Interior Overhead Light fixture dinky twinky Electrical - Systems, Generators, Batteries & Solar 2 03-08-2006 02:17 PM
Light Fixture Covers (plastic) ke4lkq Electrical - Systems, Generators, Batteries & Solar 4 01-16-2004 05:28 PM
