Old 05-02-2009, 10:17 PM   #1
2006 16' International CCD
Castle Rock , Colorado
Light cover above door - where do I get one?
I have a 16' CCD and the light on the outside above the door has some sort of weird fabricated plexiglass cover over it (not original). Where would I find an original replacement lens? It is a 2006 - not old.
Miss Vicki is offline   Reply With Quote
Old 05-02-2009, 10:30 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Any Airstream dealer will be able to order the light cover for you, they may even have one in stock.
Old 05-17-2009, 06:34 PM   #3
1973 25' Tradewind
Hendersonville , North Carolina
If you are referring to the lense and not the aluminum cover, I was able to fabricate one fairly easily by purchasing a small piece of plexiglass 12"x12" at ACE hardware, cut it on the band saw (or fine jig saw), and sand one side to make it "opaque". Cheap easy solution!
use the original as a template, if missing use just trace the aluminum cover over the plexi and shape to fit.
good luck
gottafly is offline   Reply With Quote
Light or light cover over the door.. help please! harestream Lights - Interior & Exterior 19 08-29-2008 09:51 AM
Louvered Porch light cover gowyn Lights - Interior & Exterior 4 07-11-2008 09:26 AM
Fiber Optic Indicator Light Cover Ganglin Lights - Interior & Exterior 58 01-10-2008 02:48 PM
HELP!!! Bathroom Light Cover Broke! StingrayL82 Lights - Interior & Exterior 22 08-29-2007 07:12 PM
