Old 04-07-2011, 07:07 PM   #1
1337stream
worksology's Avatar
2007 27' International CCD FB
Manhattan , Kansas
License plate light not working
After a series of blown fuses in the tow vehicle, I diagnosed my problem as a improperly-crimped line in the license plate frame. I've trimmed the power cord all the way back to the original green line from inside the Airstream (not part of the license plate frame component) and it is getting NO power to it now. No more blown fuses; ALL other running lights are working; but no luck on the license plate light. The only thing I can venture to guess is that I might have tugged too hard on the green wire at one point and loosened it from wherever it comes from (the depths of the inaccessible space between the aluminum skins). Any other ideas for why this might not be working? I've checked all the fuses in the Airstream's power box and they're all solid.
Thanks!
Josh
worksology is offline   Reply With Quote
Old 04-07-2011, 07:12 PM   #2
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
How did you determine that there is no power to it? Only because the license plate light won't come on?
Do you have one of those little screwdriver looking testers with the light in the handle?
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Old 04-07-2011, 07:36 PM   #3
1337stream
worksology's Avatar
Manhattan , Kansas
I tried one of those little tester things, but noticed it only registers 80V at the lower end. Then I tried holding the light bulb (verified that the bulb works on another outlet) directly to the green wire and it doesn't illuminate.
Fuses don't seem likely since all the other running lights work (and I can't imagine the license plate frame is on its own).
Power from the truck's trailer plug doesn't seem likely (again, since all the other lights work).
The bulb works.
I've tried to remove the license plate frame component from the debugging process, but the only way I've tested since then is touching the bulb directly to the wire.
Josh
Old 04-07-2011, 07:50 PM   #4
DanielB's Avatar
On mine the green wire runs all of the running lights and the lp light. Everything.
Just out of curiosity I just went out and took a (single contact) bulb out of a light socket and held a hot wire to the contact on the end. No light. Then I grounded the side of the bulb (metal) to the shell and put the wire to it. Light. It needed a ground.
- Andrew Carnegie
Old 04-07-2011, 08:23 PM   #5
1337stream
worksology's Avatar
Manhattan , Kansas
Oooooh. I will go try that. Thanks so much.
Update: Verified that worked! Problem must still be in the light housing. I'm gonna rewire that and will let you know how that goes.
Josh
Old 04-07-2011, 08:31 PM   #6
DanielB's Avatar
Awesome. That could have been a lot worse.
- Andrew Carnegie
Old 04-07-2011, 10:31 PM   #7
1337stream
worksology's Avatar
Manhattan , Kansas
The only problem was in the housing on my shoulders.
The extent of my testing was with the light assembly dangling from the power wire, but the (necessary) grounding is provided by the screws that hold it to the Airstream body. My assumption that it should work unattached was faulty, and many thanks to you for pointing that out.
Josh
Old 04-08-2011, 05:05 AM   #8
DanielB's Avatar
It was a hunch. I had to test it to see. I learned something myself.
- Andrew Carnegie
Tail Light Monitors? MDSilverado Lights - Interior & Exterior 3 10-19-2015 07:15 PM
Street side brake light not working w/ running lights on NicheVintage Lights - Interior & Exterior 7 08-23-2011 05:54 AM
Texas Year of Manufacture License Plates Bambi_Bandit Title, VIN & Registration 15 06-18-2011 10:52 PM
New Light for the cedar closet Dan@LED4RV Commercial Listings 6 04-07-2011 07:04 PM
Flash of Light !! donking General Repair Forum 8 01-24-2011 02:16 PM
