Old 03-27-2008, 03:02 PM   #1
vhord's Avatar
Images: 96
License plate light drain?
There is a plastic tube running from my license plate light housing through the top of my rear compartment door frame. It appears to be some sort of drain but why would it be needed and why would it be routed where it is?
Vernon
P. S. - The PO's trailer ball bracket in this picture will be removed at the first opportunity!
vhord is offline   Reply With Quote
Old 03-27-2008, 04:37 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
This is a guess on my part, but could it be a vent tube for a rear mounted battery box? My '64 Overlander has a rear mounted battery box with a vent tube that is directed to a small opening near the center rear below the window.
Kevin
Kevin D. Allen
AIR #827
Old 03-27-2008, 05:52 PM   #3
Darol Ingalls's Avatar
The license plate light is the farthest 12V electrical point from the TV connection. The tube is to drain off excess electricity after you disconnect from the TV to avoid electric shock or accidental spark. (Now, if you believe that - - - -). Kevin is, of course, correct. The original battery box had a lid with a vent that supposedly vented off battery gasses. Didn't work very well and PO's usually got rid of the box and the vent. You should provide some sort of vent for any battery except GMA or Gellcells which do not give off gasses as they charge. Darol
Darol Ingalls is offline   Reply With Quote
License plate mounting Krazyjohnny Exterior Restoration Forum 6 10-15-2016 02:05 AM
New License Plate Bambi_Bandit Title, VIN & Registration 2 11-11-2007 10:58 PM
New License Plate Bracket Airhog1 Community Polls 4 09-24-2007 05:28 PM
License plate Ball_Park145 Off Topic Forum 6 02-19-2007 08:15 AM
License Plate Holder livexl Airstream Motorhome Forums 5 07-31-2003 11:07 AM
