Old 08-08-2010, 08:40 PM   #1
Soyboy's Avatar
1999 28' Excella
Frederick , Maryland
Images: 44
License Plate Bracket Install Question
I ordered this: Truck-Lite - Catalog Product : White & Chrome Bracket, Bulb Replaceable bracket from Vintage Trailer Supply. It came with a foam gasket. Not paying attention when I took it out of the box, I assumed the black foam gasket went between the bracket and the trailer skin, and that is how I installed it. However, looking at the picture, it looks like it goes between the chrome light cover and the bracket. Is that correct? If so, what goes between the skin and the bracket? Installing it the way I did might be the reason I felt I had to caulk between the white bracket and the chrome cover. Working with these lights on an AS is a PITA with the way the wires come out of the body.
1999 28' Safari
2012 F150 Platinum Max Tow 7650 GVWR 3.73 Elec. Locking Diff.(Prev 2003 Dmax).
Honda EU2000i, Equalizer Hitch
AM Solar Panels 150W - 2 Trojan T 105 6V Batteries
TAC MD-6
AIR 4534
On internet forums, please research and separate the wheat from the chaff (including mine!)
Soyboy is offline   Reply With Quote
Old 08-08-2010, 09:48 PM   #2
bwaysteve's Avatar
1965 28' Ambassador
Irving , Texas
I just installed the same bracket.No foam gasket was included from VTS.The big black rubber gasket is for the light.The part that has the slots for the plate is attached to the trailer skin via the 2 drilled holes in the bracket.I used 2 olympic rivets dipped in vulkem and that is the only sealing you need to do.I shot some vulkem in the wire hole from the inside,but I had my inside panels off.
bwaysteve is offline   Reply With Quote
Old 08-08-2010, 10:23 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, the picture is wrong. I tried to fit the rubber seal between the chrome cover and the white bracket, but it won't fit. This was when I got a new assembly to replace the rust ball of a chrome cover. Airstream installed mine with the foam rubber seal against the trailer body and the white bracket on top of the seal. The chrome cover has no seal and that is why it rusts so quick. My original chrome cover was a ball of rust within two years. My new cover has lasted over four years so far. I made a seal out of 1/16" vacuum hose that I split on one side then slipped it onto the edge of the chrome cover. I ran out and took this picture tonight. The cover is really dirty, but still not rusty. I did not replace the white bracket so you will see a spot of rust on it. The main thing is if you can see the seal I made.
Name:	IMG_2335 (Large).JPG
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-09-2010, 05:12 AM   #4
Soyboy's Avatar
1999 28' Excella
Images: 44
Thanks guys. Robert, it sounds like it would be a good idea to make a small gasket to put between the chrome and the painted metal.
1999 28' Safari
TAC MD-6
AIR 4534
Old 04-09-2011, 09:57 AM   #5
tinbender's Avatar
2001 16' Bambi
2013 23' International
Piedmont Region , North Carolina
License plate light and bracket
I have also purchased the aforementioned replacement part for my trailer and have another question about its mounting process.
Mine came with the same gasket as the one above, which I am going to use between the bracket and the trailer skin, but it also came with 2 hard rubber spacer grommets that I haven't seem mentioned anywhere else. They are about 1/2" diameter and about 1/2" tall. I don't really see where I need them but for those who have put these parts on before, where did you use them in this assembly, if at all?
TB
tinbender is offline   Reply With Quote
Old 04-09-2011, 10:00 PM   #6
Salem , Oregon
Images: 18
TB
Hi, I haven't seen these rubber bushings. Maybe for SOB's or hot rods or maybe they will fit over the back sides of the license bolts to protect the body.
2005 Safari 25-B
Old 04-10-2011, 05:36 AM   #7
Dan@LED4RV's Avatar
Denton , North Carolina
Something that works real well on that light is put Airstreams Clear Acrylic Spray 28174W on it before you install it.That helps it from getting rusty and old looking. I knew a guy who took it off every year and resprayed it. He kept it looking like new for a long time.
Dan Brown
Denton NC
Dan@LED4RV is offline   Reply With Quote
Old 04-10-2011, 05:56 AM   #8
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I would agree with BOB.Those are rubber bumpers to keep the license plate from hitting the body.Im sure they were in the kit I installed.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 04-10-2011, 08:04 AM   #9
tinbender's Avatar
2001 16' Bambi
Rubber Bumpers
Thanks for the replies Bob and Mike. I'm thinking you're right about the use of the spacers for protection from the license plate against the body.
Dan -- I painted and/or clearcoated all of the parts, inside and out, before I installed it. Of course I had to change the white bracket to silver.
TB
Old 04-10-2011, 09:14 AM   #10
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
As mentioned above the spacers are to off set the lic. plate from the body. Not only protecting the body but will allow for installing the plate or changing the plate.
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 05-30-2011, 11:57 AM   #11
BW
1973 31' Sovereign
Baton Rouge , Louisiana
Send a message via Skype™ to BWMorgan225
TB
Can you tell me where you purchased the license plate/light from? Did not see it at inland or out doors.
bw
BWMorgan225 is offline   Reply With Quote
Old 06-01-2011, 01:19 PM   #12
Soyboy's Avatar
1999 28' Excella
Images: 44
Vintage Trailer Supply has them.
1999 28' Safari
TAC MD-6
AIR 4534
Old 07-28-2012, 07:25 AM   #13
Airstream Newby
CMSmith's Avatar
1975 25' Tradewind
Florence , South Carolina
I know this is an older thread but I have a question about installing this bracket. The old unit has a red and a grey wire coming out and the replacement only has the red. Does the grey hook up to the bracket for a ground or is it even needed with this unit now. I have a '75 Tradewind.
CMSmith is offline   Reply With Quote
Old 07-28-2012, 12:15 PM   #14
Dan@LED4RV's Avatar
Yes the gray wire from the unit is the ground and can be hooked up to the body of the light for a ground. The body of the light is ground.
Dan Brown
Denton NC
75th Anniversary License plate/bracket davidz71 Modifications 3 12-17-2012 12:09 AM
New License Plate Light Bracket Only has one wire? nick6930 Lights - Interior & Exterior 15 06-18-2009 07:51 PM
License plate question IdahoMatt Off Topic Forum 5 07-18-2008 03:21 AM
New License Plate Bracket Airhog1 Community Polls 4 09-24-2007 05:28 PM
Rusty License Plate Bracket RivetED Clearcoat, Exterior Paint & Trim 5 09-06-2004 09:09 PM
