Old 01-20-2009, 04:46 PM   #1
Phantom's Avatar
2007 19' Bambi
Delton , Michigan
Question Lenses keep falling out ! %$$##@##!@!
The lenses in the ceiling lights of our 2007 Bambi keep falling out. I find one or the other on the floor after virtually every trip. Does anyone have a solution to keeping the dang lenses in place? These are the rounded-on-one-side, rectangular in pairs, kind of new ceiling lights. They just don't snap in a fit tight. I'm about ready to look into replacing all the lights!
Phantom
Phantom is offline   Reply With Quote
Old 01-20-2009, 06:03 PM   #2
1972 Travelux Princess 25
Cobourg , Ontario
Would a couple of dabs of clear silicone help? It wouldn't show and it would still be possible to take out the lense if necessary.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 01-20-2009, 06:04 PM   #3
SteveH's Avatar
Common Sense , Texas
This may be WAY off base, but are you sure the tires and wheels are ballanced?
Old 01-20-2009, 06:09 PM   #4
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
That is the solution.
Old 01-20-2009, 06:13 PM   #5
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Welcome to the world of Airstream Quality Control. I had the same problem in the bathroom of mine. When the lights were mounted to the ceiling they were tightened up so much that it warped the frames and the lenses would not stay in. Twice in the middle of the night when I was asleep I had lenses fall out into the sink - that will get your attention in a hurry. Anyway one time when I was at Jackson Center I had them replaced under warranty. Occasionally I'll find one of the lenses loose now but haven't had one actually fall out since the replacement. I tried loosening the screws holding mine up and that didn't work for me but you might give it a try.
Al - K4GLU is offline   Reply With Quote
Old 01-20-2009, 09:28 PM   #6
altamont's Avatar
2007 27' Safari FB SE
Tracy , California
Had the same issue. Dealer replaced and all is good with the world. Major problem was in the bathroom.
2007 Safari FB SE LS
2008 F-250 Lariat Power Stroke Diesel Crew Cab
WBCCI 1538
To err is human. To arrrrrrr is pirate.
altamont is offline   Reply With Quote
Old 01-21-2009, 04:43 AM   #7
Wayne&Sam's Avatar
Images: 21
I agree that it has to do with mounting the lights on a curved surface, as they are in the bathroom. But silicone did the trick. Even after I took off a lens to change a bulb, the residual silicone keeps the lens on even though it is no longer glued in place.
Old 01-21-2009, 07:30 AM   #8
Airhog1's Avatar
1975 31' Sovereign
Searcy , Arkansas
Hey Phantom,
Are these the frosted white lenses...if they are, on the newer units, Airstream has started using different lights and lenses, they are clear instead of frosted and they are made a little different and don't seem to fall out. You might look at having them all replaced with the newer type of light...they are fairly inexpensive.
Just a thought,
G
Airstream of Arkansas
www.airstreamofarkansas.com
877-Air-hog1
877-247-4641
Keeping the Airstream Dream Alive!
AIR #8844
Airhog1 is offline   Reply With Quote
Old 01-21-2009, 08:06 AM   #9
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Boy, I had hoped that Airstream wouldn't have used these kinds of lights. Some of our elder guests with SOB here had those kinds, and the lenses would fall out every time they just closed the door. I got up on a ladder to check it out for them. The lip that was supposed to clip the lens in just wouldn't clip any more after the lens had a chance to warp with time and heat. Bad, bad design.
Lynn
WBCCI 21043
Where to find old light lenses? '77sovereign Lights - Interior & Exterior 11 12-12-2008 08:25 AM
1972 Tail Light Covers-Lenses mello mike Lights - Interior & Exterior 2 07-07-2007 10:05 PM
Good source for '71 safari tail/brake lenses bertro 1969 - 1973 Safari 0 11-28-2006 09:26 AM
REPRO '75 to '78 Rear Lamp lenses FOUND ! ALTE797 1978- 1979 Excella 500 0 11-25-2006 05:51 AM
