Old 09-25-2015, 11:47 AM   #1
2014 25' FB Eddie Bauer
Knoxville , Tennessee
left tail light malfunction
On last trip, left tail light began to malfunction while on the road. No blinker or brake light function but running light is working. Any advise on where to start trouble shooting?
Joan
2014 25' Eddie Bauer
Jfed is offline   Reply With Quote
Old 09-25-2015, 11:56 AM   #2
Goal15's Avatar
Dallas , Texas
So here's what I do when that happens with my 2006 AS. Pull the 7 pin connector out and spray some silicone spray or WD 40 into the female plug. Usually clears up the problem right away. Sometimes dirt or moisture will get into the socket and it will cause one of the tail lights not to work. I learned this trick the hard way after i had pulled tail light assembly clear off the AS (and believe me that wasn't easy) only to find out that there is no bulb that I can replace in that assembly. Hope this might be helpful
Dana
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 09-25-2015, 03:59 PM   #3
Yes, I cleaned the 7 pin connector with no change to the problem. After closer inspection I have found that the light works but the middle section of both the top and bottom lights on the left do not work on turn or brake. Does this mean that it is an LED problem?
Old 09-27-2015, 07:57 AM   #4
Rechecked signals last night, now everything is working! Thanks for the advice.
Old 09-27-2015, 01:14 PM   #5
1985 31' Limited
minden , Nevada
Tail lite out.
I would not RECOMEND WD-40 for cleaning any type of electrical contacts or components as it is not recommended by the manufacture because it is highly flammable! (says so on can) There are many spray type contact cleaners available at RV & hardware type stores. I have seen the damage that WD-40 can do when used on electrical circuits regardless of voltage, it's not pretty.
appliancetec is offline   Reply With Quote
Old 09-27-2015, 04:48 PM   #6
NWRVR's Avatar
2015 30' Classic
Sherwood , Oregon
Also, check that the tines on the female 7-way plug are bent inward to make good contact with the TV male pins. I lost my TT brakes and found that to be the cause. I clean my electrical contacts with CRC Electrical Contact Cleaner spray. I think Harbor Freight carries it.
2015 Classic 30A, Blue OX Sway Pro, 2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
Sold: 2014 25FB International Serenity
NWRVR is offline   Reply With Quote
Old 09-28-2015, 04:15 PM   #7
Smile
Thank you for all the advice. Purchased a can of CRC from my local Ace hardware today. I appreciate all the help we receive from the forum to make our Airstream adventures more enjoyable !
Old 09-28-2015, 04:22 PM   #8
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
On Edit I realize now that you fixed it. Sorry............
ShinyPete is offline   Reply With Quote
Old 09-28-2015, 07:49 PM   #9
2004 25' Safari
Steger , Illinois
I have a 2004 25' Safari, my toll vehicle is a 2014 Ford F 150. I'm having trouble with my break light and right & left turn signals, all are not working! All the light are on & working, but when i apply the breaks & the turn signals they don't work. All fuses on Ford Truck are good. Is there a short in my plug to the truck?
harleyman is offline   Reply With Quote
Left turn and left brake lights not working Morgan guy Lights - Interior & Exterior 9 02-01-2015 07:08 AM
Leak near tail light, but it's not the tail light adwriter73 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 7 03-31-2013 11:34 AM
345 LP Tank Gauge Malfunction cooperhawk LP Gas, Piping, Tanks & Regulators 1 12-06-2005 01:36 PM
water heater malfunction--help! ready to depart for xmas trip! susanborck Water Heaters, Filters & Pumps 23 12-22-2003 10:31 PM
left back-up tail light Margo Schock Electrical - Systems, Generators, Batteries & Solar 6 12-16-2002 12:52 PM
