Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 03-06-2007, 06:47 AM   #1
boatdoc
boatdoc's Avatar
Profile:  1973 Argosy 26
Norristown , Pennsylvania
LED trailer lights.
Hi all; I intend to replace the tail lights on my 1973 26' Argosy with matching size LED's. Can anyone please point me in the right direction as to where I can get them? Thanks in advance. "Boatdoc"
boatdoc is offline   Reply With Quote
Old 03-06-2007, 07:49 AM   #2
SnorkyII
SnorkyII's Avatar
Profile:  2008 22' Safari
Escondido , California
Boatdoc: Your 73 shuld have the long rectangular tail lights, if so then take a look at Champion Trailer, they have some sealed LED Tail Lights that might work. I also saw some LED boat lights at Harbor Freight the other day that might work.
I had to remove the plastic housing on my 73 Argosy, as it was startig to break up. I installed Grote Versalight Double Pod Surface Mount Units. Grote Industries: RV, Marine, and Utility Trailer Lighting I posted a picture somewhere on this site. I had a problem with the large rectangular cutouts that the factory made in the skin. I fabricated cover plates, and rivited them on and then installed the light assemblies.
I plan to convert the Grote lights to LEDs in the future. There are posts on this site of how this has been done.
Just my thoughts, Sam Halderman
Snorky II
Escondido, CA
WBCCI #2055, VAC
Charter Member FCU, WBCCI Unit #004
ESCAPEES SKP 58345
AIR #13642
08 Safari Sport 22, 03 Toyota Tundra
73 Argosy 22
SnorkyII is offline   Reply With Quote
Old 03-06-2007, 09:03 AM   #3
3Ms75Argosy
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Not exact replacements...
but I'm sure you can make something from here work
http://www.led-r-us.com/products.htm
Good luck!
Marc
3Ms75Argosy is online now   Reply With Quote
Old 03-06-2007, 09:12 AM   #4
HowieE
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
If you can not find a suitable replacement at a truck stop, almost all truck stops now have LED displays with a good selection, consider this. If you attempt to relight your current lights with LED replacement bulbs you will not get good results. Light lens are designed to be used with a given source to focus the light towards a given point.
Take a look at this posting for ideas.http://www.airforums.com/forum...23544-4.html??
I modified my lights as shown on that post as seen at #40, #49, and #51
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
marker lights dont work wb13798 Mechanics Corner - Engines, Transmission & More... 6 11-09-2002 12:40 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 10:09 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 05:51 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 09:31 AM
New trailer, old club rally Pahaska The Rally Zone 7 07-24-2002 02:26 PM
