Old 03-29-2011, 05:08 PM   #1
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
LED Tailights
Bought some LED tailights and they have 3 wires each. Black, red and white. I'm figuring the white is neutral, which is the turn signal ? or does it matter. Place that I bought them from is out of business. Hope they work!
SilverHoot is offline   Reply With Quote
Old 03-29-2011, 05:19 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
White is ground. I think the black would be tail and red would be brake/turn. If it's the opposite, you'll know right away when the running lights are brighter than the turn signals. Simply reverse the red and black if that happens.
Old 03-29-2011, 06:01 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
LED lights are polarity sensitive. I would contact the manufacture and ask for the wiring diagram.
Just wiring them and testing may not work as some configurations will not result in the lights come on at all. The "D" stands for "Diode" and diodes only pass electricity in one direction.
2004 Excursion 4x4
Old 03-29-2011, 06:16 PM   #4
SilverHoot's Avatar
1967 24' Tradewind
I don't know the manufacturer and do not see it anywhere on the light.
Old 03-29-2011, 06:19 PM   #5
HowieE's Avatar
Images: 12
Are these complete fixtures or just bulb assemblies?
Can you post a picture. If so at least the back showing the wires.
Where did you buy them? Might they have some information?
2004 Excursion 4x4
Old 03-29-2011, 06:19 PM   #6
ddstech's Avatar
1958 22' Flying Cloud
Folsom , California
Sr. Hoot,
I held the leads to a car battery and found that one is the brake/turn, one is the running light, and the last one is the ground. You wont mess it up by testing it. I can tell you which is which later tonight when I get home, but it wont be till 9pm or so.
Matt
I want to say red is the brake/turn, white is the running light, and black is ground.
ddstech is offline   Reply With Quote
Old 03-29-2011, 06:31 PM   #7
x
XXXX , XXXX
Silver hoot the ones I got from Inland RV have the same three wires. They are made by Signalstat. The white is ground, the red is running lights and the black is stop and turn signals.
wasagachris is offline   Reply With Quote
Old 03-30-2011, 07:20 AM   #8
SilverHoot's Avatar
1967 24' Tradewind
Picture?
They are complete sealed assemblies with the three wires exiting the rear. Doubt that a pic would help much but I'll snap one when it gets light out.
Old 03-30-2011, 07:26 AM   #9
SilverHoot's Avatar
1967 24' Tradewind
Thanks Matt, since you say it won't mess them up I'll probably just try what you did.
Old 03-30-2011, 07:28 AM   #10
SilverHoot's Avatar
1967 24' Tradewind
Thanks Wasa!
I 'll give the 1st try as you suggest.
Old 03-30-2011, 07:31 AM   #11
x
XXXX , XXXX
Silverhoot you can easily see visually which is brakes and which is running lights. Brakes and turn signals is very much brighter than running lights. BTW wear sunglasses if holding them close they are really bright. I could see clearly around my shop in the dark with just the clearance lights on.
Old 03-30-2011, 05:04 PM   #12
SilverHoot's Avatar
1967 24' Tradewind
Got it!
Red is for the stop/turn
Black is the running lights
White is the neutral/ground.
Thanks everybody!
Michael
Old 03-30-2011, 10:54 PM   #13
SilverHoot's Avatar
1967 24' Tradewind
Proof
Yeah!
Old 03-31-2011, 12:18 AM   #14
ddstech's Avatar
Folsom , California
There you go. Looking good!
2011 27' FC led lights Road Geezer 2009-2015 Flying Cloud 7 01-10-2012 06:23 PM
LED interior lights: A complaint hampstead38 Lights - Interior & Exterior 0 03-23-2011 08:38 AM
LED replacement for '64 Auto-Lamp 7" taillight Globie64 Lights - Interior & Exterior 8 03-12-2011 07:37 PM
Running Lights LED - How do I route the wire? AirHome Lights - Interior & Exterior 6 02-20-2011 07:15 PM
LED Interior lights Matt Kline Lights - Interior & Exterior 1 02-19-2011 05:31 PM
