Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Old 02-07-2007, 02:08 PM   #1
Profile:  2005 30' Classic S/O
la mesa , California
Led Tail Lights For Classics Et Al
BARGMAN NOW MAKES REPLACEMENT LED TAIL LIGHTS FOR SERIES 84/86. REMOVE ORIGINAL, PLUG NEW INTO SOCKET. AVAIL @ PPL MOTOR HOMES WWW.PPLMOTORHOMES.COM
vetdr is offline   Reply With Quote
Old 02-07-2007, 02:25 PM   #2
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Hello Vet-
Could you please double check the link. It didn't work for me.
Thanks for the info!
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 02-07-2007, 02:26 PM   #3
1960 24' Tradewind
Here, see if this works. Again thanks for the heads up!
Used Motorhomes and Other Consigned RV Sales - PPL Motor Homes
J. Rick Cipot
Sandi Gould
WBCCI #3411
AIR #17099
2004 22' Safari
1960 24' Tradewind
Old 02-07-2007, 02:35 PM   #4
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Here is the page on the lights
Lights
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
2006 GMC Sierra 5.3 V8
WBCCI 1754 - AIR # 6281
Member of VAC
www.balrgn.com
www.balrgn.com/Airstream.htm
balrgn is offline   Reply With Quote
Old 02-28-2007, 11:31 PM   #5
Profile:  1992 34' Limited
Falls Church , Virginia
More TT LED applications??
Hello all -
Still looking for LED's to replace the taillights/turn/backing lights on SilverToy. She is a '92 and has the triple light set - hoping for a plug and play that will make her as visible as possible.
Hoping this bump helps me find what she needs....
Thanks!
Axel
SilverToy
SilverToy is offline   Reply With Quote
Old 03-01-2007, 08:04 AM   #6
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 12
I look at your posting for the LED lights but did not see one that is a direct replacement replacement. If there was one please advise.
One thing to consider when replaceing a bulb with another type of lamp is the fact that the original lens was designed to focus the light from the original source. With that in mind you should change the complete assembly using a system designed to be used a one.
If you review this post http://www.airforums.com/forum...ts-23544.html?
You will see how I approached the issue. Look at replies 40, 49, and 51 of the post.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 25 12-03-2008 07:50 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Trailer lights Dbraw Electrical - Systems, Generators, Batteries & Solar 1 09-13-2002 04:51 PM
replacement tail lights for 69 Airstream bgow 1969 Overlander 0 08-06-2002 10:03 PM
Tail lights Chuck Electrical - Systems, Generators, Batteries & Solar 0 07-08-2002 01:58 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
