I have a set of
12v LED lights I would like to put on the outside of our Airstream, just below the rolled up awning. I see these installed and I like how they look. Some, including mine, have the option of colors and traveling lights also. My question arises on the installation. The ones I have are designed to operate on a 120v circuit and are powered through a transformer reducing the voltage to
12v. Can I eliminate the transformer and directly power the lights using the trailers
12v power. I can obtain the 12v at one of the fantastic fans and run the wires to the outside from the fan housing. If this will work I should be able to run with and install.
ThanX all. See ya on the road sometime.
