Old 08-02-2008, 05:59 PM   #1
jpeterman's Avatar
1972 27' Overlander
Graham , North Carolina
LED running lights
I was talking to my friend at CarQuest about replacing my running lights. He suggested LED that look exactly like my lights, excet when they light up.
What do ya'll think?
Jerry
jpeterman is offline   Reply With Quote
Old 08-02-2008, 06:10 PM   #2
blacksheep's Avatar
1965 26' Overlander
1962 24' Tradewind
Vincennes , Indiana
Go for it! Less current draw than filament bulbs.
Godspeed,
Trent
TV1: Black Sheep, 2001 Dodge 3500, 800,xxx miles, a few non-stock parts here and there...
TV2: Brownie, 1989 Dodge W250, only 256,000 miles!
TV3: 2004.5 Dodge 3500, 415,000 miles, 6 spd
TV4: 2005 Dodge 3500, 478,000 miles, 4spd auto
"Too much of what I once knew I now know not" Me
blacksheep is offline   Reply With Quote
Old 08-02-2008, 06:15 PM   #3
Charlyf
Charlyf's Avatar
2008 20' Safari SE
Carmel Valley , California
Send a message via Skype™ to Charlyf
LEDs seem to last forever
Charlyf is offline   Reply With Quote
Old 08-02-2008, 06:38 PM   #4
davidz71's Avatar
1986 25' Sovereign
Southern Middle , Tennessee
I went that route.
ID:	64944   Click image for larger version
ID:	64946   Click image for larger version
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 08-02-2008, 07:15 PM   #5
lewster's Avatar
Naples, FL , Hood River, OR
All '08 Airstreams now sport LED running lights. I'm very close to converting all of mine to the new style to go along with my all LED interior.
Old 08-02-2008, 07:20 PM   #6
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
A worthwhile idea. I went to LEDs this year. Power draw is near nill and there is no noticeable heat at all.
Old 08-02-2008, 07:26 PM   #7
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I replaced all my running lights in my trailer. I burned out a few in under a year. I travel with them on all the time. I switched to LEDs. they look fine and are about 1/2 the current draw.
Michelle TAC MT-0
Sarah, Snowball
Old 08-02-2008, 07:32 PM   #8
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
I put LED lights all around on our Argosy, and am now in the process of upgrading our Sovereign to LEDs.
Old 08-02-2008, 07:39 PM   #9
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We just converted Lucy to all LED running lights. We we even did the step and patio lights. We didn't change any fixtures, just the bulbs. The 15 LED running lights are brighter than the old bulbs. The whole conversion cost about $100 and took 20 minutes.
Brian
ID:	64954   Click image for larger version
SuEllyn & Brian McCabe
Old 08-02-2008, 09:33 PM   #10
LED's
As I see it, LED lights only have one basic problem.
Their life time, exceeds ours.
Seriously, they are brighter in the daylight than the incandescents are at night time.
Old 08-03-2008, 06:36 AM   #11
Well Preserved
1993 21' Sovereign
LED's cost about twice as much as a comparable incandescent fixture, but last a hundred times longer with virtually no maintenance. If they last the first few trips (called infant mortality), they will last decades. You might have one unit fail. A friend installed LED running lights on his motorhome, and noticed almost no voltage drop with the LEDs, versus almost a volt and a half voltage drop with the standard lights.
Old 08-03-2008, 06:46 AM   #12
Plus, the sealed LED's do not have any rust or corrosion problems.
Old 08-03-2008, 07:22 AM   #13
jpeterman's Avatar
1972 27' Overlander
Thanks everyone for the response. I'll change out as we are doing our upgrades.
One question I had was how did you measure the voltage drop before and after installing the LED lights. I can understand a amp drop but not volts.
THANKS AGAIN FOR ALL THE HELP. (some of us need it)
Jerry
Old 08-03-2008, 07:57 AM   #14
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
My new LEDs did not come with gaskets so I had to make some from gasket material I got from an auto parts store. The gaskets are not necessary for a weather seal but for me were necessary to mount LEDs properly to the skin. No big deal.
LED lights SteveH Lights - Interior & Exterior 22 09-17-2007 10:58 AM
LED running lights...maybe! wasafari Lights - Interior & Exterior 16 06-25-2007 08:00 PM
LED Running/marker Lights-Teardrop BornToRock Electrical - Systems, Generators, Batteries & Solar 2 12-18-2006 12:46 PM
led running lights anyone? wasafari Lights - Interior & Exterior 6 01-13-2006 03:51 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
