Old 02-28-2012, 05:21 AM   #1
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
LED Retrofit issue and reading light front assembly
I ordered the replacement LED lights for the entire interior of my '06 Safari that used 1156 regular bulbs and the reading light halogens. Everything was easy until I got to the reading light/halogen fixture. They contain a silver metal insert that is mounted internally with two phillips screws. The LED pancake pad's two rear contact wires are not long enough to be installed on top of the silver insert without unscrewing the inside insert mount. Is that what others of you have found? The light works beautifully and is a major improvement IMO but is that the solution you have found?
Secondly, I discovered that my AS has a missing front lens and twist on front on one of the nickel lights. Is there a place to buy just the front assembly of a reading light instead of buying the whole fixture for $30?
02/12: New Tire Discussion on Woodalls: LT versus ST and more. slowmover Tires 128 04-10-2012 05:09 PM
Replacing Fluorescent Lights with LED 10Smiles Lights - Interior & Exterior 6 03-22-2012 01:48 PM
Front Forks Fun! casa3805 Clearcoat, Exterior Paint & Trim 25 03-08-2012 09:01 PM
Where do i buy ? Light fixtures / tale lights Front lights missing Airgirl1 General Repair Forum 4 02-27-2012 05:04 PM
Tekonsha P3 and Grand Cherokee Tallgrass Towing, Tow Vehicles & Hitches 2 02-26-2012 05:02 AM
