Old 11-29-2008, 09:23 AM   #1
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
LED Replacement for '64 Bargman
I am looking for recommendations for an LED replacement for the original Bargman Wedding Cake brake/turn signal lights on my '64. I want the replacement to look close to the original, within reason. I am not sure which Bargman # I have, but here is a picture:
Name:	Bargman Brake Light 1964 IMGP2344.JPG
ts8501 is offline   Reply With Quote
Old 11-29-2008, 09:38 AM   #2
Unfortunately, that design went out many years ago.
Smooth tail lights are the order of day, today.
We have a direct replacement 7 inch LED tail light.
Part # 65601
Old 11-29-2008, 09:40 AM   #3
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
bus lights
Hi, I found that 7" school bus lights work great. I've seen them on e-bay for as low as $36.00. They are very bright and a nice fit. You have bargman 99 Lights. LP
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 11-29-2008, 10:16 AM   #4
1967 22' Safari
1960 Caravel
Images: 8
Covers
One more thing! If you want the original look Vintage Trailer Supply sells the covers. Look here. LP
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 11-29-2008, 11:42 AM   #5
Images: 59
Shameless self-promotion, but here's what I did.
Old 11-29-2008, 01:44 PM   #6
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Hey Mark.. that's a great idea...and some extra white led's too!
Thanks!
Marc
Old 11-29-2008, 01:49 PM   #7
Images: 59
Those extra LEDs work great as closet lights.
Old 11-29-2008, 01:50 PM   #8
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Here's another conversion... (not mine)
LED tail light conversion on a 1964 Airstream Overlander
I think there were a few other well documented conversions here on the forums - just use the search function above...
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 11-29-2008, 04:21 PM   #9
HowieE's Avatar
Princeton , New Jersey
Images: 12
I would not suggest using any form of MIX and MATCH as far as LEDS and original LENSES.
Tail lights are designed to focus the light from the original light source using the lens design to project the light in a chosen direction. Any change in the positioning of the source will reduce the effectiveness of the light.
Tampering with the optics of the fixture is not only an engineering point but most likely a legal point as well.
2004 Excursion 4x4
Old 11-30-2008, 07:58 AM   #10
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
'64 Replacement Decided and Thanks!
Thank you to all that have written so far with replacement options. I think I like this one the best, as it allows for reuse of the original light covers.
Thanks GreatPumpkin for passing it along, but no thanks for the pile of pooh. I had to see that before I ate this morning
Old 11-30-2008, 12:01 PM   #11
Images: 70
Here's a few more links for various styles / years. Including an alternative process used by HowieE - that wouldn't work well with the cake lights you have though.
http://www.airforums.com/forums/f311...hts-23544.html
http://www.airforums.com/forums/f37/...ion-17847.html
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Old 11-30-2008, 01:03 PM   #12
HowieE's Avatar
Images: 12
I trust you can see the difference between post #3 and #49 in this link as to the effect the lens has on the light pattern. It looks like we both started with the same light.
As for mounting a complete LED fixture into the lens of the old cake type lights that should no be as hard as my installation. There are tail/brake fixtures that will fit in the upper section of the cake lens.
2004 Excursion 4x4
Old 12-02-2008, 07:13 AM   #13
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Hold the phone! I do not have Bargman 99's. I have Auto Lamp 575's. Here's another thread, drop down to #40.
http://www.airforums.com/forums/f150...a-46195-3.html
Old 12-02-2008, 08:09 AM   #14
1967 22' Safari
1960 Caravel
Images: 8
Bummer!
Looks like you are right. Well, the bus LED lights should cover the holes. But, I can't say for sure. I like to keep the original look were I can with a modern twist if I can get away with it. On the Safari the back lights were rusted out and at the time we rebuilt it economical replacements were not available. So, it got the LEDs. Looks like you have a challenge on your hands and I've learned something new about Airstreams. I'll post a picture if you like. Good luck!
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Bargman '86... S C Streamer Lights - Interior & Exterior 11 05-19-2015 03:33 PM
LED Replacement for Halogen Cabin Lights nangoff 2002 - 2005 International 19 10-27-2014 10:56 AM
'71 tailight LED replacement Lumatic Lights - Interior & Exterior 1 05-03-2008 09:30 AM
LED *Power On* lamp replacement Safari Tim Electrical - Systems, Generators, Batteries & Solar 4 03-31-2005 10:58 AM
