03-10-2011, 08:35 PM
1964 19' Globetrotter
South Kingstown
, Rhode Island
LED replacement for '64 Auto-Lamp 7" taillight
Hey- I thought I saw a post about someone who had replaced older tail lights with LED units but cannot track it down- forgive me if I'm duplicating another thread. My '64 Globetrotter has the Auto-Lamp 7" tail lights and needs new lenses. I'd love to replace it with the same kind, but the Auto-Lamp lenses are rarer than hen's teeth. I like the idea of using LEDs and have found these. Questions: am I correct in assuming that a modern turn/stop/tail fixture will be an okay swap for the old one? Is it bad to swap out a wedding-cake tail lamp for the flat, modern LED? I kind of like it, the size is the same, they're kind of over-sized scale on the back of the trailer, but the flat shape is more minimal. I use LEDs in my work and really like how they function. Thanks
Wherever you go, there you are
03-10-2011, 08:44 PM
South Kingstown
, Rhode Island
oops, this is what I'm thinking of using: Grote 53422 7" Red Turn LED Lamp, and the wedding cake type is like the existing, except not sunburned and cracked.
03-10-2011, 08:45 PM
South Kingstown
, Rhode Island
ugh, shown together, the LED is pretty ugly compared to the old one.
03-10-2011, 09:26 PM
1963 16' Bambi
Stevens Point
, Wisconsin
Globie,
I mounted the LED base into my original tail lenses. When I turned them on, the lenses made this crazy starburst pattern. I figured this would attract a lot of attention from those that patrol our highways. I switched them back to 12V.
Tim
03-10-2011, 10:40 PM
South Kingstown
, Rhode Island
Beaker- you mean you switched back to the incandescent lamping?
03-11-2011, 10:33 AM
Moderator Emeritus
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna
Greetings Globie64!
You may find the following threads to be helpful in your search for alternatives: I applied the technique described in the Vintage Tail Light Blasphemy thread on my 1964 Overlander and have been very happy with the results. The only issue that I had was with establishing a good ground upon initial instaqllation, and have only had one minor issue with that ground since then.
Good luck with your project!
Kevin
Kevin D. Allen
WBCCI (Lifetime Member)/VAC #7864
AIR #827
1964 Overlander International
03-11-2011, 12:10 PM
South Kingstown
, Rhode Island
Thanks for the leads Kevin- it helps to have the incandescent option from Optronics.
Peter
03-11-2011, 09:37 PM
1963 16' Bambi
Stevens Point
, Wisconsin
Globie,
Yes I switched back to the incandescent bulbs. I wasn't ready to give up the original lenses. I have to look at the threads Overlander located, might be hope yet.
Tim
03-12-2011, 07:37 PM
South Kingstown
, Rhode Island
OK, well I ordered the incandescent Optitron lights but will keep my eyes open for NOS Auto-Lamp lenses.. I like that they're kind of rare and unusual. The new ones are kind of cool and simple, school bus lights.
