i am trying to replace the bulbs in my reading lights in my 1965caravel with led bulbs.
sounds easy right? just buy 1141 base leds and pop them in.
not so fast................the 1141 bulb glass tapers up from the metal base.
the 1141 led immediately gets thicker at the end of the base.
the leds wont fit in the aluminum lights because they cant go in far enough.
a longer base would work.
has anyone had this experience and any ideas on a fix?
I tried a number of bulbs and none worked due to a slightly thicker base than the regular bulb. I think that the solution is to use a die grinder and widen the opening in the reflector ever so slightly. I just haven’t taken the time to do it yet.
Installed mine today. The space between the arrows is too great.
Take the switch nut off pull out the guts of the light and push the reflector in further.
It pushes really hard but solves the problem.
Versailles
, Indiana
The reading lamps in our 1966 Safari appear to be the same as the one in Dingo Girl's photo...how do you get the bulb out? I am not sure if I should be twisting it, pushing in the reflector, both? I am hoping to switch the original bulbs with LEDs as they get too hot and I'm already having flashes just thinking about them!
Thanks so much!
Jenn
Robb, Jenn & The Brown Dog (Dex)
Maizie, The Black Dog, May You Rest Peacefully
2005 Safari 25
WBCCI #4447
AIR #70157
Between the 2 arrows in the picture you can see the slot in the bulb socket.
This is what holds the bulb.
Push down on bulb and turn slightly. It should pop right out.
