Old 09-22-2013, 05:25 PM   #1
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
LED Marker lights - Different style
While in the process of getting the parts to start working on the resurrection of our 73 we are thinking on LED marker lights.
Again we are thinking outside the box, and we know that we are not the only ones, so here is the question:
Did anyone upgrade the marker lights to LED with a different style other than the traditional 2x4s?
How about something like this?
Miro Flex Red SEALED Surface Mount LED Marker CLEARANCE Light Optronics | eBay
Please any idea or suggestions will be great!
And for all of you that had upgraded your marker lights please feel free to post some pics.
Thanks in advance
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 09-22-2013, 06:00 PM   #2
1972 23' Safari
Camas , Washington
check this out
Marker and Running Lights : LEDs 4, Recreational Vehicles
Pams72 is offline   Reply With Quote
Old 09-22-2013, 07:21 PM   #3
mapleton , Utah
try Grote or Truck Lite, many non traditional choices.
tim
rumrunner is offline   Reply With Quote
Old 09-22-2013, 08:00 PM   #4
1973 31' Sovereign
2007 20' Safari SE
Thanks guys, options it doesn't looks like will be an issue.
We are more wondering if someone has done it in their airstream
2 chronicles 7:14
Old 09-22-2013, 08:30 PM   #5
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
New LEDs
Of course, if you change designs, then you are probably going to have to drill more and different holes to make them fit. I got all of my new LEDs from LED4RV. They look great, are sealed against the weather and are BRIGHT.
I installed an inline switch with a dimmer...so I can have running lights on in camp....but turn them down to a low roar.
ID:	196229   Click image for larger version
arktos55343 is offline   Reply With Quote
Old 09-22-2013, 08:34 PM   #6
1973 31' Sovereign
2007 20' Safari SE
sweet pictures,
Just my impression or you have done a lot of skin replacement?
2 chronicles 7:14
Old 09-22-2013, 08:37 PM   #7
1972 25' Tradewind
Hopkins , Minnesota
No skin replacements on mine...a lot of polishing to get rid of corrosion. But otherwise, it has its share of dings and bumps.....character.
Old 09-22-2013, 08:49 PM   #8
1973 31' Sovereign
2007 20' Safari SE
thanks for the pictures and sharing, so if no skin replacement, how did you loose the rear compartment door? PO legacy?
Is that a twist & lock stainless steel shore power in the front?
2 chronicles 7:14
Old 09-22-2013, 08:57 PM   #9
1972 25' Tradewind
Hopkins , Minnesota
To my knowledge, I had no rear compartment in mine. It had a rear bath...which was a mess....and the major cause of the rebuild with a rear bed and a side 1/2 bath.
The front has a Marinco genset inlet. The 30amp shore power inlet is the same unit mounted on the street side.
Old 09-23-2013, 05:01 AM   #10
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Thanks in advance
Just replaced the brake/turn/tail lights on the boat trailer with Optronics 10 led kit. Quality product, well sealed, at a good price.
Good product selection.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-23-2013, 05:49 AM   #11
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I'm kind of a fan of these...sold out, unfortunately. They have a 9 LED version, though.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 09-23-2013, 06:25 PM   #12
1973 31' Sovereign
2007 20' Safari SE
http://www.airforums.com/forums/f447...ing-51905.html
post 5 & 8, that's out of the box!
Sure you can see that Airstream in the highway!!!!
2 chronicles 7:14
Old 09-23-2013, 06:39 PM   #13
1972 25' Tradewind
Hopkins , Minnesota
Ah, to be fair, I wired all of the tail lights together just to test them. So the reverse lights won't be on on the highway...and the turn/brake will only be half as bright. But I'm digging the brightness of the clearance lights... I don't think I will be missed on the highway. May have to wire in a switch for the reverse lights....to flash if somebody gets too close to me. LOL
Old 09-23-2013, 06:41 PM   #14
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
I have all LED running lights Veggie Bullet but I simply replaced my bulbs rather than the fixtures. I used the amber and red LED in the appropriate fixture. WHAT a difference it made - bright deep color.
