Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar > Lights - Interior & Exterior
Prev Previous Post   Next Post Next
Old 05-29-2009, 06:08 AM   #1
Profile:  1965 24' Tradewind
Warner , New Hampshire
LED Marker light grounding.
I would like to install LED marker lights on my 65 tradewind. The original lights are grounded to the body through the rivets. Can I use the second/extra wire on the LED lights to make a universal ground for all the lights? I would connect the power to the light then connect the ground to a ground wire run it to the next one and so on until they all terminate to a designated area. he tail lights are wired this was because of the plastic housing they are installed into. I have the interior gutted so doing this won't be a probelm. Is there anything that I'm missing? Is it worht the extra effort or should I just ground them to the body like the original lights?
Brian
briheath is offline   Reply With Quote
LED marker lights hampstead38 Lights - Interior & Exterior 6 10-31-2008 03:27 PM
Marker lights: Incandescent or LED hampstead38 1967 Overlander 9 10-07-2008 09:16 PM
New Airstream LED Side Marker Lights NeatAirstream The Vendor's Forum 5 02-06-2008 06:34 PM
LED Running/marker Lights-Teardrop BornToRock Electrical - Systems, Generators, Batteries & Solar 2 12-18-2006 01:46 PM
LED Clearance/Marker lights Safari Tim Lights - Interior & Exterior 13 10-24-2003 10:54 PM
